Important Notice Regarding Phantom 2 Firmware v3.10
There have been a small number of reported issues with the latest Phantom firmware, v3.10. In response to these reports, DJI has proactively suspended this firmware update.
If you already updated your Phantom firmware to v3.10, please reset your firmware to the prior version (v3.08) immediately. To do this, connect your Phantom to your PC, launch the DJI Phantom Assistant software, and follow the standard procedures for updating your firmware. V3.08 has now been designated as the latest version, and your Phantom will be reset.
If you have not yet updated your Phantom firmware to v3.10, and your current firmware version is v3.08, no action is necessary.
If you are running an older Phantom firmware version, DJI suggests that you update to v3.08 now.
Check your firmware status and apply any available updates by connecting your Phantom to your PC, launching the DJI Phantom Assistant software, and clicking “Upgrade”.
iOS Note: Some iOS users have reported issues when using Phantom firmware (v3.08) with the iOS VISION app (v1.0.46). To address this issue, the iOS app has been updated and is now available in the App Store. If you require the VISION app to fly safely, please update to the latest version (v1.0.48) before flying. No update is required for the Android version of the VISION app.
If you have any questions, please contact [email protected].
Thank you,
DJI
I saw this post this morning and reset the firmware to 3.08 on my Phantom 2 (non-vision) as advised. I have a Zenmuse H3-3D gimbal installed. I use the Mac version of the Assistant software to do the update. When the older version of the software was installing the Zenmuse Gimbal started moving up and down and sideways and making a real grinding noise. When the install was done I recycled the P2 and now my gimbal is dead. I've recalibrated the controls and the IMU. But nothing seems to work. When I power on the P2 the gimbal doesn't do the normal startup sequence it used to do before.
One additional piece of information... On the Upgrade tab in the Assistant app there was an upgrade listed for H3-3D Gimbal so I chose to do that upgrade. The upgrade was installed but now it does not even list the H3-3d Gimbal anymore on the Upgrade tab.
I have FPV installed and I am sill getting iosd data and the GoPro is still sending a picture so the at least part of the electronics for the Gimbal is working.
Does anyone have any suggestions? I'm lost.
brianklenhart
