HOW TO: Build your own iPad Mini sun shade
msinger
Approved Vendor
Harrisburg, PA (US)
Website
phantomhelp.com
I didn't build one. I'm just sharing for those who'd like to build one v.s. buy one :)
Reactions: Numone
I did build a sunshade for my i-pad mini.
Used materials: 1/2mm photocardboard, black gaffer tape, sheet of pre-glued velvet.
I made it out of 3 pieces. I didn't use tabs or glue, but I used gaffer tape instead.
The top and the back is a folded panel. the side panels are separate.
The inside I lined up with black velvet.
A rectangular opening at the top to let the holder trough.
It is more then sturdy enough for normal use.
You should Patton that dude.. Lol Pretty cool look.
I used black Depron 3mm .....
Cut panels to size and then black tape joints.
To have it held - cut an under tablet panel same size as tablet .... then cut out a slot at top and bottom edges to let holder insert ... cut similar from back vertical panel.
The slot in under tablet panel must allow holder to grip tablet.
Nigel
Reactions: jcnava
Scav8tor
