At the CES show I was told that the Carl Zeiss Cinemizers will again be available this spring.... probably what I'm going to wait for..
Will the samsung gear vr work with hdmi module?
Not without a hack
I've never tried it myself, but it requires you actually taking the connector off the VR to avoid plugging in the phone and using Litchi appWhat hack is it I've got a galaxy s6 so it would be perfect for me
No you can't.You should be able to do this with an iOS device as well. You'll just need the Lightning to HDMI adapter.
No you can't.
Yea I'm connecting nvidia shield to HDMI adaptor to fat shark v2 attitude goggles got a cheap USB powered adaptor here 1080P HDMI to Composite 3 RCA AV CVBS Video Converter DVD CRT Apple TV PS3 SKY
PS you do not have to buy HDMI module to get goggles connected to P3P!
Buy a tablet from Nvidia Shield K1 (android) instead, with this you get HDMI out and also can record what on screen. just plug goggles to HDMI (mini) port and you have picture. I have HP and it awesome.
See here what I have:I also have HDMI module but this is for TV ;-)
iOS device doesn't accept HDMI input signal.
You are right.The iOS device doesn't need to accept HDMI input for it to output HDMI to goggles. I just tested it, and mirroring the iOS screen to the goggles works fine. The problem, however, is that the Lightning pass through on the HDMI adapter only seems to pass power (not data). So there's no way to connect the controller to the iOS device while the apple HDMI adapter is connected.
Tony: Yes, I take it down a little. I also change lens picture got smaller.
I took down brightness å bitBidda, what settings did you change? I also changed the lens
So what is the difference in the goggles off HDMI from an Nvidia tablet, the HDMI module and where do these VR headsets come into play?If you want to use VR headsets, currently you need to use apps like Litchi for android or Fpv Canera.
