Help outer battery shell needed for p3
Wez
hi folks
I have an issue dropped the battery on my p3 advanced Oops
Battery inside is fine and worth saving
But outer white she'll is cracked to bits
So long shot does any one have a dead / non genuine battery that I could have / purchase
Just for the outer shell
Pretty please
Am based in uk
I have a once used non genuine batt but at £40 feel it is too expensive for you to cannibalise.
Thanks for replying
And yes is a bit much
Are u still using the fake battery ?? And if so what firmware version are u on
I don't think its worth using a cracked shell battery as you really don't know what all has gone bad with it.
Reactions: ROD PAINTER
Fair point but it's £120 and says it was all fine when in drone but just unsure about cracks to casing and the security when flying as basically broke of the front bit
I have already removed the cells ect from the plastic case and all looks good
Just seems a waste otherwise
You are the best judge for the current state of the battery and yes batteries are expensive. If choice is given to me, I won't play with risk of fire. I will skip two - three dinners outside and buy a new battery for $80-100. Let me admit I don't have guts like that you have.
Don't get me wrong I will use this as an excuse to buy some more :)
Just wanted to know if I could do it and succeed
SAFETY NOTE to anyone thinking of taking apart a phantom battery
If u hit one of the cells/ battery inside it will very very likely burst in to flames or blow up in your face !!!!!
brianklenhart
