Help on installing prop-guards: quick question
I just received the Bestem removable prop-guards. It is supplied with the longer screws needed.
1. What kind of wrench/driver is used to remove the screws? what size?
2. Instructions call for applying thread lock to all screws. Is this a good idea? Which kind? I understand that there are issues with the plastic.
Thanks
Larry
Screws use a 2.0mm hex driver or Allen wrench and as far as lock tite I don't use any . Some use the blue but never the other .
I have never had a problem not using any and really think as easy as these screw head's strip I won't never !
I do check all the screws occasionally but that's it .
+1 dc.
No Loctite.
Inspect frequently.
Reactions: dirkclod
Thanks
Is there a tool kit that has the tools i will need for the Phantom?
Scav8tor
