GoPro 3+ Black Wifi Question
Central Mississippi
I have looked around and haven't really found a definitive answer so hopefully someone here with a GoPro 3+ Black can help me.
I have what may be an odd question but I have an FC40 and have been trying to use that camera. It is probably the worst camera made as far as reliability. If I start recording and wifi drops, the recording stops.
I already have a GoPro HD Hero without wifi and am pretty happy with the quality but I want to be able to frame my shots when i'm in range.
Now for the question... if I start recording with the GoPro 3+ Black and wifi drops out, does the recording continue?=
Part 2 of the quesion (or maybe it's another one :D ) can you reconnect to the wifi preview while it is recording when it gets back into range?
Thanks in advance.
Tommy
I'm a little confused what you're asking but if you are talking about the GoPro's wifi i suggest you never use it near your phantom or it could crash. Interference is a common issue. Anyways my GoPro's wifi distance is very limited and wouldn't be a good solution for your problem. To answer your question, yes if you start recording and your phone looses the wifi signal the camera will still record.
Thanks in advance.
Tommy
Yes the GoPro Hero 3+ will continue to record even if you loose the WiFi downlink. Since you fly a FC40 phantom which is remote controlled on 5.8gHz, and uses a FC40 camera which already operates on the 2.4 gHz band, it should be safe to use the GoPro Hero 3+ with WiFi (2.4 gHz) enabled.
I only want to be able to frame my shots, not really use it for navigation.
Also, I realize the range is poor. I setup a wifi repeater from my old linksys router with dd-wrt firmware. It helps the fc40 camera range but that camera is still crap.
That sounds great. Can you describe how you setup your linksys with DD-WRT to use with the FC40 camera? There is a 14 year old kid at my RC club who flies a FC40 who would love the extended range on the FC40 :) (I plan to use the TP-Link TL-WR702N)
There are a few long threads about that in the fc40 forum. I believe I have a post detailing how to do it with the linksys as well as the new portable TP-link router.
search for MR3040 or TP-link and you should find it.
Also search for WRT54G (for the linksys version)
AnndyManuka
