Gimble Overload P3
After a small crash (5 feet or so) with my P3 standard, I now have a gimble overload on DJI app. The camera gimble shakes from side to side while the camera moves around irratically. I have searched Yiutube and tried a couple things with no avail. Any help or advice would be appreciated
I think your ribbon cable got disconnected when you crashed. My buddy crashed his mavoc and had the same issue. He sent it off to dji and they sent him a new one for 130$ he did not have dji care.
Or the yaw arm shifted on the motor shaft. Grub set screw on arm should sit square on the flat side of the motor shaft.
Real easy fix with 1.5mm hex driver if this is the issue.
Other motors may have skewed from their correct orientation.
Thank you all. I did check the set screw and the other motors. No luck. I'm going to go down the ribbon path and replace it since I'll have apart checking on it. Thanks again.
