I bought a used cheap P3S the other day, it was advertized with a gimbal that had been broken in a crash, fixed mechanically but would not come good.
I'm no stranger to electronics and found many places where thrashing gimbals were described and could be fixed - mostly by aligning the horizon potentiometer.
So I set out trying my luck.
This is what the gimbal looks like:
As can be seen, the yaw axis always goes to the end stop and the others do so to varying degrees.
The rol Axis sometimes stabilizes almost horizontal, while the tilt axis mostly goes to it's bottom most stop.
I have taken apart the whole assembly and tried to make sure I get the alignment right when putting it back together.
The Yaw arm is fixed with the worm screw on the flattened side of the axis. The roll arm is fixed such that the flattened side of the axis points up and is parallel with the top of the camera.
The camera is fixed such that the dji logo on the lens is upright when the drone stands on the landing gear.
Interestingly, I have had some success calibrating two of three gimbal axis when the drone is sitting upside down (roll was ok, tilt was off ~25deg, yaw was at an end stop)
I have looked at the horizon poti and found that it shows strange values. Throughout the motion range of the gimbal, the resistance jumps from ~5kOhm to ~40kOhm - can someone confirm that this is right? Is it broken? Is there a replacement part? (I'm currently trawling for mechanically broken Gimbals to slavage electronics)
See video on the resistance:
I have already updated to the latest firmware - which had no effect.
I'll keep digging, but unless I have some gross oversight, I don't quite know where to go next, it seems all the basics are covered.
Any suggestions?
thanks & kind regards
pj
Any suggestions?
pj
