Gimbal shaking uncontrollably
Hey guys,
I bought a secondhand Phantom vision 2 Plus, however (and I knew this before buying). There are some issues with the gimbal.
The camera still works, but if I take the protection guard off it does this:
Not ideal, no idea how the fix this. If it is fixable at least..
I tried this: How to fix a vibrating / shaking / crazy P2V+ camera gimbal
that did fix it a bit, however; it's still not practical..
Any ideas?
Try recalibrating the gimbal
Hey guys,
Any ideas?
You are on the right path..
But maybe your D shaft is upside down. Rotate it the other way and see how you go.
Other things could be:
Loose grub nut at top yaw motor (less likely)
Damaged potentiometer (sensor position) in the tilt or roll motors.
brianklenhart
