Fpv instability
I flew 3000ft out at 65ft and was getting instability quite a lot. This isnt very far and what would happen if i decide to fly 1 mile out?
Try going higher sometimes the signal gets stronger
What device were you using?
Depends on your environment, antenna etc. Behind any trees?
Check your antenna orientation - have the flat sides parallel to the craft - basically straight up to the sky should work best if the phantom is some distance off.
Could try lowering the bit rate of your video feed to to the lowest setting, 4mbps.
There were trees around and buildings... I flew low at 65ft because thats the highest i can go in the area
tpren3
