Re: FPV Booster App DOUBLE FPV Range
(1) In case Wifi module malfunction (it happens so often, like black out FPV screen or connection broken) and you need to send your bird back to DJI, there is no trace left possibly void the warranty (if any).
(2) When you perform any firmware upgrade/downgrade, it will not cause any conflict or compatibility issue.
(3) It's not too easy to be copied by other clone apps.
I hope we can finish the re-work of coding by the end of this week, and will start testing CH-7 next week. If everything goes fine, we will then submit to Apple/Google for approval. The difficulty is that we are seeking a very neat and high quality CH-7 software component loading & running on P2V+ memory (RAM) without copying/modifying any stock DJI files. After power cycle, all booster/CH-7 components are gone. There are various advantages of this approach.ResevorDG said:Any luck on the 7tth cannel app? Any idea of a release date?
Thanks fpv
