Flying 2 phantoms together, strong interference.
South coast UK
I went out with my pal last night for a flight (my P3A and his P3P) we set up and started waiting for the crafts to warm up, by my friend noticed that he was getting a warning that there was strong interference and be careful on long range flights? This spooked us a little so we didn't fly at the same time in the end.
If I walked away with my craft the poor signal would change to good? It seemed to be my craft interfering with his rc and visa versa. What do you guys think, was it perfectly safe to fly?
some have used the 32 channel hack for when they are flying together then they choose the different channels manually so they don't interfere ...
You can do the same thing using the original frequencies that came with your Phantom by simply changing the setting from auto to custom. Then picking 2 different channels.
I've flown 3 at the same time and I've noticed that the phantoms will often change channels and 1 phantom can override the next causing a total loss of signal. The way to avoid this is having all the phantoms in the same vicinity on their own channel by manually selecting. I would strongly avoid using auto setting when flying more than 1 phantom in close quarters.
Reactions: dtokez
I flew 2 the other day and the only issue is when the controllers were right next to each other. When separated by a couple feet, all was good.
I presume by having two next to each other the RF of one was overloading the front end of the other's receiver. A reasonable distance separation solved the issue.
Reactions: dtokez
We can't see the option to select channel manually in either of our apps? I guess dji have taken the option away?
The channels you can change are for video link.Channel 13 to 20.
Go to settings ( top right corner) of Go app.
Go tp the " HD " , select " custom" instead of " auto"
Pick a channel. Other P3 do same only pick a different channel
Reactions: dtokez
There there is no option to manual select on either of our apps?
We've flown 3-6 at a time a number of times and while there is some interference and you're certainly not going to do any super long distance flights, it's always worked pretty well for me. I'm on channel 32 and I think most of the guys don't have the hack and so are not interfering so much with me.
Reactions: dtokez
lol cool video :)
did you notice if you had a warning when checking your signal quality?
Thanks.
I kept an eye on signal quality bars in case we needed to not stand too close together and they never dropped, and we had no warnings.
We were not going for any long distance, prob 300m max, and we were in the middle of a field so maybe in a busier rf environment ie near houses/wifi etc it may be more of an issue..
Michello
