Find my Phantom - no map!
Aberdeenshire, Scotland
Find my phantom doesn't seem to work as expected.
Using Android 4.3, latest app ver 1.0.32, and also tried it on a friend's ipad. In both cases the PV and the device have good gps fixes.
Go to settings-> find my phantom 2 vision
I get :
1. A brief bit of chinese text.
2. My phone appears as blue dot and aircraft in red pin. but the background is not a map just a blank grid...
3. On the right bottom corner shows in red : Baidu地图
Anyone had the same issue?? Or found a fix?
I believe there is an issue with the Android version and the map not showing,
but works OK on my iPhone 5 App (1.028)
I did find that you need to disconnect from the Phantom Wi-Fi and get either
Internet access through the phone or a Wi-Fi network.
When I tried "Find my Phantom" when still being connected to the PV2, all I
had was the grid and pushpin.
Dave
Ok, I've now found that it seems it will only load maps via a mobile signal, not wifi....
And as most places I am have poor signal and no 3G that's a bit .. useless.
Even when it decides to load a map it's in Chinese and and is just a white screen if you zoom in to closer than all of Europe!
Now if it flew far enough to need that scale....
Dave
ditto iphone5 - disonnect and use 3G
If it works similar to the DJI ground station software I have with
my Wookong M, then a Chinese map shows when there is no internet connection if local
maps cannot be found.
To combat this without internet access, I had to view google maps of the location I was going to fly in, and
also zoom the map a little, all at home before I left to fly. This must have cached the area, and it was able to show
the map without the internet.
No idea if this will work with the PV2, but I have just turned off Wi-Fi and put my iPhone into Airplane mode, and
I can still view the location I flew earlier today, even after I closed the App and restarted it.
Worth a try maybe.
Dave
Yes, it does seem to have cached the map -- but it's still in chinese and had no detail if I try and zoom in closer than all of western europe.... Be better if they used google maps!
Ok.. Just had a play with the app on ipad mini.. Which has no mobile or gps, just wifi. The maps work fine once you zoom in and out a bit. All in english, and it has a satellite view from google earth...
So it's just the android app that's totally screwed map wise!
This is probably just common sense... but it's not how I thought the "find my phantom" ap worked. I shut mine down in a field down the street and it's still showing there... Then I realized that it works via GPS and I can't get a signal in the house, even though I turned on the Phantom and controller. The location on the map is the last known location of the phantom when it had GPS lock. I think... No?
-slinger
robvalduga
