Meta4
Premium Pilot
- Joined
- Jan 8, 2014
- Messages
- 15,303
- Reaction score
- 9,247
I've read a lot of questionable ideas on forums but I think this is the prizewinner .Try to think logically first, before acting like that. Read the forums.
Why? Presumable because you feel that ritual will make you "safer".
There is no need to recalibrate the IMU before each flight.
Most Phantoms never need an IMU calibration.
And there's no need to calibrate the compass every flight either.
This kind of over calibration is anti-safety as it just increases the potential for getting a bad calibration every time you do it.
Rather than superstitious actions, simply reading the manual is a much more effective method to ensure safe flight.
That's not logic and it's not simple .. it's ridiculous.
When you remove the props, you hold a motor and turn the prop.
There's no way it would put any pressure on the shell.
Your theory is nonsense.
The manual is very sparse on details of many things.The manual does not provide the information you have provided here
I wasn't shouting anyone down .. but since the OP was making up his own procedures that aren't based on sound practice, in the belief that it might improve safety I was pointing out how this could actually do the opposite of what was intended for the benefit of anyone that might have thought it was a good idea.Not sure why you are shouting him down. Relax
The manual is very sparse on details of many things. But experience and understanding of Phantom flying helps fill in a lot of the blanks.
The manual doesn't even mention calibrating the IMU.
I didn't suggest anyone fills in the gaps themselves.Righto. Interesting approach you have to non-experienced users there - read the manual but fill in the gaps yourself? I don't think calling him superstitious is very helpful at all.
His actions were superstitious - that's what it is when you do things you don't understand as some sort of ritual.I don't think calling him superstitious is very helpful at all.
The manual states to calibrate the compass in every new location, not that you can over calibrate. Over calibration isn't mentioned, and I'm not sure common sense would indicate such a thing is possible.
Are you drunk?Nonsense? Whatever man. On and off on and off - that is how you brake anything.
How far away was your Phantom from the home point?it was at 15% when it went from a steady hover to a vertical climb, the controls were totally unresponsive.
Do not remove propellers. It will result in shell cracks. Do not attach prop guards. Read the manual. What I can say, I am sorry man.
Or... is it? The P3 is not supposed to ascend to the RTH altitude when within 20m of the home point. Some people here are claiming that's what happened though -- and, telling the OP to read the manual. Something doesn't add up.Just another case of someone not reading and fully understanding their phantom
All should be fine if you do not over tighten the props. If you're worried about putting pressure on the motors/arms when tightening or loosening the props, then hold the base of the motor while doing so. Anything is possible I guess, but I'm not going to worry about this one. I remove my props after every flight.Screwing on the props and screwing them off again all the time causes wear, for instance on the prop's inner threads.
Where did the op say he was within 20 meters of his home point . Are we just assuming he was? Plus he has never shown us the flight logs or replay . So that tells me the phantom did exactly like it was suppose to and he's now probably reading the manual . And probably is thinking o crap I should've read this first.Or... is it? The P3 is not supposed to ascend to the RTH altitude when within 20m of the home point. Some people here are claiming that's what happened though -- and, telling the OP to read the manual. Something doesn't add up.
He did not say. That's why I asked him. It seems everyone is just assuming they know all of the details. The OP has not given us enough information though.Where did the op say he was within 20 meters of his home point . Are we just assuming he was?
You are right. Donating my p3 to the museum at Dulles airport today. No way can it continue to suffer the forces of flight. I mean geesh.Logic is simple. Plastic is very thin. Any pressure and it will be enough.
