- Joined
- Mar 13, 2017
- Messages
- 12
- Reaction score
- 2
- Age
- 50
Long time lurker - first time poster. I wish it were under better circumstances.
Flying my P4 Pro in cottage country Ontario. Not the first time - but as it turns out it was the last time.
Pre-flight check, battery at 100%, waited for 11+ satellites and strong GPS signal - waited for home point to be set - then took off from shore over water (see attached link and map below).
Flew close to an island in the lake that wasn't very far (0.5 miles). Aircraft lost both video signal and remote control signal all of a sudden all at once. Message on iPad was 'Aircraft Disconnected'. So me thinks - no big deal, calmly wait for the Aircraft to initiate RTH. RTH was pre-set at high enough to clear trees 260 feet (80 meters) - mostly flat water everywhere anyways.
After a few minutes - no reconnection and no signal. I pressed RTM on the controller, tried the sticks - nothing. Then a bunch of error messages started showing up on the screen, I listed them all below - however they are in the link I shared below as well. Main ones during flight were Compass disconnect, switched to Atti mode by itself, Battery Overcurrent during discharge, Motor overloaded, overheating during discharge, low temperature during discharge, critically low voltage (suddenly from 62% to low???), weak GPS, etc... Long story short - after several hours of searching and no luck I figured the drone is in the water at the bottom of the lake.
With Aircraft shown as disconnected - the DJI App was showing a termination point in the middle of the lake. However, the .txt data file I extracted from my iPad and uploaded to AirdataUAV much later - the full flight path was shown. Clearly - the drone was transmitting, just not showing as connected and DJI App info wrong?
- Bottom line - found the drone submerged in the water 3 feet from shore the next day based on the Airdata website. Nowhere close to Home point or anywhere close to what the DJI App was showing.
- Aircraft was fully under water for close to a day
- completely undamaged - not even a scratch on it
So now what? Clearly - something malfunctioned. as a result - it went down into the water. Definitely not my fault. Still under warranty. How does one go about dealing with this and am I out a drone?
LINK: Airdata UAV - Flight Data Analysis for Drones
WarningWarning:[compass]disconnect (In Flight) please switch to atti mode if craft behave abnormally (Using)T06m 45s79.6 m606 mWarningWarning:[compass]disconnect (In Flight) please switch to atti mode if craft behave abnormally (Using)U06m 50s79.7 m560 mModeMode changed to Confirm_LandingV06m 50s79.7 m560 mWarningObstacle Avoidance will be disabled in landing.W06m 51s79.3 m552 mWarningWarning:Motor Overloaded. Aircraft will decelerate to ensure safety.X07m 04s45.2 m538 mWarningBattery:Overcurrent During DischargeY07m 04s44.1 m538 mModeMode changed to AttiZ07m 04s44.1 m538 mWarningWarning:Compass Error. Exit P-GPS Modea07m 17s77.4 m528 mWarningWarning:Motor Overloaded. Aircraft will decelerate to ensure safety.b08m 00s97.4 m487 mWarningWarning:Motor Overloaded. Aircraft will decelerate to ensure safety.c08m 20s111.9 m460 mWarningBattery:Overcurrent During Discharge Low Temperature During Discharged08m 20s111.8 m460 mModeMode changed to Confirm_Landinge08m 20s111.8 m460 mWarningObstacle Avoidance will be disabled in landing.f08m 20s111.8 m459 mTipCritically Low Voltage Warning Land as soon as possible, or battery will be damaged.g08m 23s108.3 m457 mWarningWarning:Motor Overloaded. Aircraft will decelerate to ensure safety.h08m 24s105.8 m456 mModeMode changed to Attii08m 24s105.8 m456 mWarningWarning:Compass Error. Exit P-GPS Modej08m 30s111.1 m452 mWarningBattery:Overcurrent During Discharge Overheating During Discharge Battery Error. Return home and land soon. View the checklist after landing.k08m 51s110.9 m441 mWarningBattery:Overcurrent During Discharge Overheating During Discharge Battery Error. Return home and land soon. View the checklist after landing.l08m 55s111.0 m437 mWarningBattery:Overcurrent During Discharge Overheating During Discharge Low Temperature During Discharge Short Circuit During Discharge Battery Error. Return home and land soon. View the checklist after landing.m09m 24s117.4 m426 mWarningBattery:Overcurrent During Dischargen09m 27s117.3 m425 mWarningBattery:Overcurrent During Discharge Overheating During Discharge Low Temperature During Discharge Low Voltage Protection Battery Error. Return home and land soon. View the checklist after landing.o09m 27s117.3 m425 mWarningWarning:Motor Overloaded. Aircraft will decelerate to ensure safety.p09m 31s117.1 m425 mWarningWarning:The remaining battery is only enough for RTH. Return home now.q09m 31s117.1 m425 mModeMode changed to AutoLandingr09m 31s117.1 m425 mTipTips__Critically Low Power. Aircraft Landings09m 31s117.1 m425 mWarningObstacle Avoidance will be disabled in landing.t09m 46s102.3 m422 mModeMode changed to Confirm_Landingu09m 48s98.8 m422 mWarningBattery:Overcurrent During Discharge Battery Error. Return home and land soon. View the checklist after landing.v09m 51s90.2 m423 mWarningWarning:Motor Overloaded. Aircraft will decelerate to ensure safety.w10m 03s56.8 m427 mWarningBattery:Overcurrent During Discharge Overheating During Discharge Low Temperature During Discharge Short Circuit During Discharge Low Voltage Protection Battery Error. Return home and land soon. View the checklist after landing.x10m 24s16.0 m438 mData LossDownlink data connection lost for 5.6 secondsy10m 24s15.5 m438 mWarningWarning:The remaining battery is only enough for RTH. Return home now.z10m 25s14.0 m438 mModeMode changed to AutoLandingA10m 25s14.0 m438 mTipTips__Critically Low Power. Aircraft Landing
