Cheapest FPV Build? (<$200)
(Phantom 2, H3-3D gimbal, GoPro Hero 3+)
Hi there, I've been asked to do a real-estate job in two weeks as a test run for a realtor I know, but I'm nervous about being able to take quality shots without the aid of an FPV setup.
So, what would be the absolute cheapest setup I could buy that would provide the POV of the quad? What would be the medium-priced setup? Thanks guys!
Going to be Tough go get in under Two Hundred.
I have a dozen real estate customers (in my HVAC business) and real estate was part of my justifications for the P2.
I put my FPV system together for $308.00 (including shipping) and I consider that to be on the Low end. With making a circle around a house you can get by with the stock cheap-0 antennas. It is Possible to shoot the property with no FPV. You'll only need 3 or 4 minutes after you edit it (and that would give you 10 minutes or so to cut out). You could leave out the isod Mini and save $70.00 which would put you at $230.00 which is Darn close to $200.00.
http://www.phantompilots.com/viewtopic.php?f=31&t=22926
I shot a house late Sunday and the Wind was 15mph and flying very high was Scary. I'll post the video.
[youtube]https://www.youtube.com/watch?v=W_t3ViRTfoo[/youtube]
it's going to be around $70 for the transmitter, and about $200 if you get a blue pearl monitor which has the receiver built in.
I've looked around, and getting FPV for below $300 is hard.
You could just by the Transmitter and a Receiver if you already have a monitor. That's the only way.
http://www.readymaderc.com/store/index. ... cts_id=877
and
http://www.readymaderc.com/store/index. ... cts_id=266
I don't think that receiver has antennae so you might need to purchase some.
http://www.readymaderc.com/store/index. ... ts_id=3192
under $200 is possible, but I'm not sure if you can do that within 2 weeks. Your BARE MINIMUM system could be:
Boscam 200mW transmitter: $25
Boscam RX-LCD5802: $150 shipped from overseas (probably not less than 2 weeks). You could maybe find it domestic for 180 or so?
With that low power and stock antennas about all it'll be good for is surveying a property but it should work... however if you go Boscam transmitter, there aren't any pre-made cables so you're going to have to solder at least 4 wires (2 for power, 2 for video)
If you go with an ImmersionRC 600mW, your transmitter jumps to $70 and there's a $21 no-solder cable you could use, so now with the aforementioned display you're at 240.
Mike said:
Don't forget the quantum goggles. They're only $30. Not the greatest, but you can't beat them for the $$.
http://www.hobbyking.com/mobile/viewpro ... duct=53706
ok wow, that is indeed cheap! So going with that Boscam 200mW you'd need the $48 kit that includes a receiver instead of just the $25 transmitter.
goodness, that's FPV for under $100. granted it's crap and you have no range but still...
jorge sanchez
