Cant calibrate compass or get gps on drone
Any help with this is appreciated.
New P3 working fine in the UK yesterday. Arrived to Switzerland and it wont calibrate compass and forces me into Atti - mode.
The error message Im getting is attached.
Ive tried a different location to reset compass with no success.
No really sure what the problem is, to top things up the map was showing the right location where I am...
Gps shows as 0
Are you inside? If so, you should calibrate it outside.
Are you trying to do this indoors?
Look at the compass sensor info in the app.
Is the compass data showing some numbers? - find an appropriate location away from steel and it should calibrate.
Is it showing zero - the sensor is damaged or the cable is broken or disconnected.
No GPS and high levels of electromagnetic interference ..... sounds like you're indoors.
Definitely in a bad place for calibration
You are certainly at the wrong place. That's what error message shows. You got to move out to a new location until error message disappears. Looks like you are inside a concrete building where multiple wifi networks are working together.
tpren3
