The highest resolution is always best.What camera setting for still or movie would be best if I were going to have a 24x36 print made?
The phantom sensor is actually 4:3 aspect (4000 by 3000 in round numbers), not 4:5 as @Wheatfield proposed. This is an important fact as it provides for the opportunity to appreciate what quality to expect in a print. That is we simply divide 4000 our longest proposed print dimension to arrive at dots per inch (DPI). It is commonly accepted that 300dpi is the point where the benefit of any higher resolutions become imperceptible in the resultant output. I actually prefer to resize source files to 288dpi as it evenly divides into 1440 which is the magic number most printers have as the native print head resolution and i have learnt that photoshop resizes more accurately and with less artificts than some printer drivers produce when rescaling input files.
So, at 300 dpi your maximum print file can be just over 13" wide with excellent (as good as your sensor can produce) quality.
180 DPI will give good quality when viewed from a reasonable distance (about 22" wide).
At a stretch to 24' your at 166DPI. You can get a reasonable result here however artifacts, particularity noise will be apparent when viewed closely. Your best results will be obtained by shooting in good light (low ISO and short exposure) and exposing towards the right of the histogram. You want the best signal to noise ratio you can squeeze out if the sensor and as much information as you can get in the darker areas. Resize to desired output resolution, in this case for 23' your output file should be 6624 pixels on the longest dimension. Apply sharpening last.
Two things I didn't mention. Consider flying in closer and shooting a Pano to give you a higher mp image to work with. You can also get cleaner image files by shooting several frames (5 or more for best results) and doing a stack align and median blend in photoshop. This will greatly reduce noise.
Taking stills will always be better than taking screenshots from video.I've had reasonable luck taking screen shots from a movie with an current imac.
some so good that I wasn't sure if taking snapshots would be any better? Will snapshots always out perform screenshots?
I have a pro with 4kIt's difficult to answer your last question, before knowing which version of Phantom you fly.
Is yours a Phantom 3 Advanced or Professional version?
Using stills from a Pro' with 4K video, will certainly outperform an Advanced camera at 2.7K.
RedHotPoker
When you say the screenshots were good I'm guessing you were viewing on your iMac screen? Depending which iMac it is you may be veiwing close to or above native resolution of the screen so the screen grab so it should look. Printed at 24" by 36" however it will have significantly less resolution than a still image for the reasons Meta4 has outlined.Thank you so much for the information. I've had reasonable luck taking screen shots from a movie with an current imac.
Best Resolution
Still = 4000 x 3000 (Pro & Advanced)
Video = 4096 x 2160 (Pro) 2704 x 1520 (Adv)
And video shutter speed is likely to be much slower than would be used for stills so taking a screenshot you are likely to have a much less sharp image.
Photoshop ... or any other decent image editor. There are quite a few to choose from.Thank you! I'm using final cut pro x, but i'm not sure if this program is designed for editing still shots? What program should I use for this?
