Brandnew Phantom 3 adv. is dead
Southern France
Hello,
I have received totay the Phantpm 3 advanced, I did all updates with success and did also a couple of flights without any problems. Atfter landing of the last flight the phantom turns off. I thougth it is fact of the low battery charge about 20% but when I tryed to start up the phantom with a fully charged battery, no reponse of the phantom , no leds or beeping, he w'ont turn on ...
Thanks in advance
Edmund
Do the LED's on the battery light up?
tap the button once then hold it for 2 seconds until all the lights come on. maybe you just aren't holding the button long enough
I think your holding the button down too long on the second press should be 2 seconds not 3 or 4
Send that video to dji and I'm sure they fix it
Will the battery stay on, when it is not in the phantom?
Could have been worse, you at least saw it work.
Hi there
I've got news from DJI, one esc was burned
Fortunately it has happened on the ground and not in the air.
It is strange an esc burned after the first few flights, newer happened with my other copters.
Wow, that is cooked, makes you wonder about the rest.
Scav8tor
