bloquage de vol à 30 m
Bonjour, je suis novice sur le DJI phantom, mais depuis que j'ai fait la mise à jour proposé sur le site DJI pour mon phantom pro, il est calibré à 30 m en hauteur et distance et si je veux l'enlever quand je vole c'est un risque car il a un moment de déséquilibre, avez vous rencontré ce probleme et puis je le faire avant de décoller. Par avance merci
OK, even google translate isn't helping me much:
Hello, I am new on the DJI phantom, but since I did the update on the proposed site for my pro DJI phantom, it is calibrated to 30 m in height and distance, and if I want to take it off when I flying is a risk because he has a moment of imbalance, you have encountered this problem, and then I do it before takeoff. Thank you in advance
Any French speakers? Google some times gets it right, othertimes .....
Here's what I got WD /
Hello, I am a novice on the phantom DJI, but since I did the update on the DJI to my phantom pro site, it is calibrated to 30 m in height and distance and if I want to remove it when I fly it is a risk because there a moment of imbalance, have you encountered this problem and then I do before taking off. In advance thank you
OK stil not sure what the OP means:
- 'calibrated to 30 m height'. Perhaps he / she is thinking of the RTH height? Imbalance is probably not the word the OP is looking for but again, I'm not sure just waht the question actually is.
Magic 8 ball says, 'reply hazy, ask again later'.
Reactions: dirkclod
Bonjour Hommage , je ne comprend pas la partie « calibré à 30m» . Est-ce ton «return to home (RTH)» ou le mode «beginner». Peux-tu aussi expliquer ton «moment de déséquilibre» .
A+
Reactions: dirkclod
Tribute Hello, I do not understand the "calibrated 30m" part. Is your "return to home (RTH)" or "beginner" mode. Can you also explain your "moment of imbalance."
For us multi language impaired.
Actually the translation isn't so bad , even in french it is not claer as what is the problem . I'm thinking more that he is in beginner mode and the Phantom is kinda wobbling when it hits the 30m limit .
Il le dit bien dans son message dès le début qu'il est NOVICE, donc il n'utilise surement pas les bon terms
From the start of the message, he tell he is a NOVICE (beginner), so he probably not using the right drone word.
Nous avons besoin de plus d'explication, We need some more explanation
you are stuck on beginner mode. get rid of beginner mode and it will get fixed :)
Bonjour, je suis novice sur le DJI phantom, mais depuis que j'ai fait la mise à jour proposé sur le site DJI pour mon phantom pro, il est calibré à 30 m en hauteur et distance et si je veux l'enlever quand je vole c'est un risque car il a un moment de déséquilibre, avez vous rencontré ce problème et puis je le faire avant de décoller. Par avance merci
Oui, comme d'autres l'on déja dit il y a bien des chances que la mise à jour a remis des valeurs de configuration par défaut tel que le mode débutant. En général après une mise à jour, il est recommandé de véfier toute la configuration et refaire toute les calibration IMU, compas et gimbal.
I just summarize in French what was said before by Viper989 and Digdat0 and my 5 cents.
Bjr communauté, je possède le phantom 3 standard, je voudrais savoir comment désactiver le mode debutant, vous remercie .
Bjr communauté tt d'abord dans le premier corps de mail je me suis trompé, ma demande est tout simplement, comment désactiver le mode debutant sur le phantom 3 standard vous remercie de votre retour.
Bien a vous tous
Jojo de la Réunion
DonT
