Black hawk still down
So I found out last time I posted that my ipad 3rd generation wasny gonna cut it so now I have updated to the ipad4 mini and woop de woo I have had a few days to get over the size of the app dji go, so now i have stopped the bleeping tx by calibrating it. I formated my mini usb waqtsit and dragged the bin file from the dji site and i get this.
========== 2014.01.01 00:00:10 remo-con disconnect======
Packet: P3S_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.08.03 06:33:52 =====================
Result: Abort.
========== 2016.08.03 10:41:48 =====================
this balarnnle goes on for some time I only copied 4 or so times but it repeats itself with one more "success" at the end [choke]
I can do the compass calibrate in the app, everything is reading normal but when I do the inward salute with the tx ....no motors spinning i get two green double blinks and two red solid lights and ....nadas please help
What exactly are you attempting to do? It would be helpful if you attached the entire log file.
Do you mean the front arm lights are solid red and the rear arm lights are blinking green?
Which message is displayed at the top, center of DJI GO?
I want the motors to spin , would be great, I'll post the rest of the log file when I get home
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
========== 2016.09.22 16:40:47 =====================
Result: Abort.
do you buy those extra or are you jesting?
no rubber bands bahaha
Your log looks good. It's showing the latest firmware was successfully installed.
Can you answer my other questions above?
yes
I brought two birds the other is up and running? I'm losing hope with this one
That LED color and screenshot above look okay. Did you try firing the bird up outside?
Scav8tor
