Assistant
Uk
Hi, guys,
I plug my controller into my PC and in Assistant select RC but it does not recognise it. If I click on "Phantom" at the top it says Controller not connected. If I connect the Quad to PC the Assistant displays all readings from Quad and controller. With controller switched on but not directly connected. Have seen a Utube vid of someone just connecting controller and calibrating it. Just wondered what I'm doing wrong.
Kenjancef, Thanks for your help have now got RC Assistant software and calibrated the Controller. What are the Mode 1 and Mode 2 options though?
Use mode 2. Since you have calibrated the RC unit you also have to calibrate the sticks in the phantom software as well with the RC turned on.
This is the Phantom 2 page. What are you doing posting about a Phantom 3 ?????
Sent from my MotoE2(4G-LTE) using Tapatalk
I can't get mine to connect. Tried everything !!¡!
What can't you get connected?? The more info you put into a question helps in giving a solution to ones problem.
