Are there any battery powered field monitors w/ MINI hdmi....
,or are they all standardised hdmi inputs?
If there is such a thing, can anyone please link one here.
You can get a mini HDMI to standard HDMI adapter at Monoprice (and others). A very useful little thing to have. Most professional / semi pro HDMI monitors will use the full sized connector. Mini HMDI connectors are *very* fragile.
Reactions: tml4191
Look at the specs on IKAN site. Converting mini ti regular HDMI using an adapter is not a problem but check the detailed specs. You can also use a cable with different connectors at ends as an option.
I know this; thank you though. I have an extra cord, so before I invest in a monitor, I was wondering if I can find a field monitor that has that MINI Hdmi input, and if not, it's all good.
If you are looking for goggles then you have many options. I thought you need a monitor.
Reactions: tml4191
