saao said:
The utility app worked well at 18 dbm both wifi and camera i flew 4500 feet with fpv then it disconnected. I think ill have to buy a 2.4 ghz amp as well.
4500 feet, eh? That's more like it. LOL. Not bad, not bad at all, I bet you're very pleased with that
With a 2.4Ghz amp you'll be getting out over a mile, no problem, but don't forget to use the app to turn down the output of the Range Extender a bit so you don't flood the new amp.
____________________________________________________________________________________________________________________________________________
mede8er said:
All you need is one of these....I run 2 6v and a 12v amp from one battery pack with this step down unit soldered in line to the 6v units...
Mmmmm, using a step down unit to supply two different voltages from one battery is a good idea, Mede8er, I should have thought of that. I have been toying with the idea of using this step down unit to supply two 12v Sunhans amps from one 22v lipo on my RC controller.
http://www.ebay.com/itm/Mini-Power-Dual ... 1075949903
