Is there any work around of the 500 meter limit? I hit that limit today and I could have easily gone another 100 meters to get above the mountain I was filming. You can see the video here:
No .. and the setting in the app allows you to set limits less than 500 metres - but not more.Is there any work around of the 500 meter limit?
There's a lot more in the sky than high altitude jet aircraft.I dont know why they imposed this limit. I have the same problem cant fly over some mountains. Airliners fly at 30,000 feet so not much chance of hitting one of those. Obviously if you fly near an airport you could but then if you are that stupid the 500m limit wont protect anyone.
Private aircraft at 1000' urban or 500' rural areas for starters.There's a lot more in the sky than high altitude jet aircraft.
You can disable the distance limit, not the altitude.I thought the 500 m could be turned off which sets it to no limit?
Directly overhead can often be an issue unless you correctly orient your antenna. I try to avoid directly overhead as much as I can.For what it's worth, I haven't even managed to get near 500 meters yet with my P3P - I keep getting weak RC signal flash up when I get to about 300 meters, even if it's almost directly overhead. Nice looking video though, shame there's nothing quite as majestic as that in South East London to film
