Wrong props
Sweden
The older model (9443) isn't bad, the 9450's just give a little more lift. They're each stamped clearly so you can tell them apart but you can mark either set if you want to be sure. I own both types and use each as often as the other.
Thanks for the reply but you can't descend to fast with the 9443 props.
Someone did a comparison test on aload of props & the 9443's stayed in the air for longer
Ok maybe i keep them is there some way to avoid VRS?
dlr11164
