Thinking of building a 550
Utah
I'm very new to the whole RC heli gig but totally into photography. I'm thinking of building a 550 for aerial photo/video purposes, so I can carry a larger payload and have longer flight times.
I'm not able to find a list of parts needed or anything like that. What do I need to build one? Is there a checklist or instructions on how to build one which isn't a youtube video?
Thoughts? Better suggestions?
You have a Phantom now?
I switched from a Phantom to a F550, but am still missing my first FPV / video flight. Reason for moving was more stable platform and larger payload. Have the following;
F550 arf kit
Futaba T8J TX+RX
Naza M V2 + GPS
zenmuse plate F550
retractable landing skids
Arris CM3000 gimbal
iOSD mini
DJI can hub
immersion 600mw tx
immersion duo rx
8" FPV screen
tripod legs for screen
5000mah 3s + 5000mah 4s batteries
Where did you obtain those 5000mah batteries? I just built a Jumper 600 and probably could use one or two. Would prefer a USA source.
I ordered a parallel XT60 harness yesterday. Was thinking of just using two of my Phantom's 2200mah batteries in parallel until I came to a decision on a proper 5000mah battery.
PF
mediaguro
Just order a DJI Flame F550....all the parts are there...just some assembly time needed. Plus there are different configurations depending on how much money you want to spend
Thanks thetac,
So I've found a few that range in the $370-$499 area for what seems to be everything needed for the body with no remote and no battery. Does that sound correct?
This Kit comes includes the following
1 x F550 Flame Wheel Frame Set
6 x DJI 2212-920kv Motors
6 x DJI 30A OPTO ESC's
6 x 10" Props/Blades
6 x 8" Props/Blades
So I'd need a controller and battery?
Can the controller for the phantom control the 550?
You would need a separate transmitter and receiver...I use a Spektrum DX8...and an AR8000 receiver. If you go this route it is cheaper to buy your transmitter/receiver as a kit....plus you will get the altitude reporting pieces you need with the kit...a good price on the DX8 kit is around $439.....but you might find one cheaper....just insure it is a whole kit....i bought mine all in pieces and it end up costing me $600
F550 arf kit
Futaba T8J TX+RX
Naza M V2 + GPS
zenmuse plate F550
Arris CM3000 gimbal
iOSD mini
DJI can hub
immersion 600mw tx
immersion duo rx
8" FPV screen
Claust - how are you finding the Arris 3 axis gimbal? I'm very tempted by one.
I have nearly the exact same bits and pieces as you and am thinking of making the jump to a F550. I would only do so if (like you) I got the retracts ! :)
What sort of flight time are you getting with that set up?
Thanks
thetac said:
I use these in my boat...very good battery....tried two of them on my DJI 550 Flame....seems to fly well but no longer than on one 8000........ here's the link
http://www.amainhobbies.com/product_inf ... Mgodo2gA1A
Yeah...that's a good one. This one comes from Sri Lanka - but look at the price! $17.77
http://store.slrcnetwork.com/product.php?id_product=84
Might have to wait three weeks (just a guess) but hell, <$18.00???? One thing I noticed are the dimensions. Only 17mm thick but 71mm tall and 150mm long. Since it's going to be slung underneath my Jumper 600 anyway, those dimensions work great for me! I may go ahead and start the purchase procedure just to see what the shipping costs might add. Probably $50.00 LOL!!!!
EDIT: Shipping for two batteries would be $18.00, BUT, I couldn't order any because their web site says the country I selected (USA) requires selection of a state - and there is NO WAY to enter one. There is no pull down menu, and every effort at entering a state in any other address field failed.
PF
