- Joined
- May 28, 2014
- Messages
- 12
- Reaction score
- 1
I am having problems with my tarot 2d gimbal as of right now. I have looked around and have found no solution. I have tried to tighten down the set screw on the back of the gimbal with no luck. it works fine at times but when i go to use the tilt control it starts to act up.. however if it is facing all the way down (filming the ground) it seems to work fine and the footage is smooth as it acts normal.. as soon as i rotate the camera so it is filming straight out it seems to shake and the footage is terrible.
this just started happening it has worked fine in the past. another thing i noticed is when it was actually filming good footage with the gimbal not shaking the tilt control would not work and i was unable to film the ground.
gimbal facing the ground = good footage no shake
gimbal facing straight out = shaky footage
gimbal facing straight out on another flight 20mins later = good footage no tilt control
