My range has fallin of drastically after upgrade. Any thoughts on this subject? Before I could fly out 900 feet easily, now I lose control at 300 feet. Batteries fully charged, way out in the country with on interference.
wildcatter said:I did the very same, also in fcc mode. I actualy had no problems for some time. Today I have very little range. I hooked back up to PC and changed back to phantom mode to see if my range came back. Still the same 300 ft.
wildcatter said:I was very careful not to do just that. I am using rechargeable batteries. They have worked just fine. I checked the voltage after a charge and it is only 1.3 volts.... this may be the culprit.
rbarghini said:wildcatter said:I did the very same, also in fcc mode. I actualy had no problems for some time. Today I have very little range. I hooked back up to PC and changed back to phantom mode to see if my range came back. Still the same 300 ft.
Perhaps you pinched the attenna after upgrading the Tx? Just got back from a flight. I was 900 ft away, 1, 000 ft up - no problems...
MrFlats said:rbarghini said:wildcatter said:I did the very same, also in fcc mode. I actualy had no problems for some time. Today I have very little range. I hooked back up to PC and changed back to phantom mode to see if my range came back. Still the same 300 ft.
If you use the Pythagorean Therorem you were actually 1,414.213562373095 feet away from your P2V.
(I think my Geek is showing)
Jeff
MrFlats said:I just heard from Dronefly. They confirmed that the Phantom 2 Vision has a ceiling limit of 400 feet AGL, if you push it beyond that, it will return to home. This is unsatisfactory. What if you fly up a canyon or up hill? Crash.
