P4 blinking 1led battery
posted this thread already bit similar to this video. Charging still blinking after 20min lights off. Even not charging it remains 1led light blunking green light . Not charging . Im pretty sure need replace.
There are many others on here that know a lot more than I do about the technical details. I would be looking up what the fast blinks followed, by the slow blinks, then off mean. Count the blinks and see if it is consistent. That is an error code of some sort.
When filming that video had you just landed and plugged it in?
Check page 25 of your manual, when you press once the lights will show battery life(not charge) you show one light, than means you are at 20 to 30% life. does your charger charge other batteries (could be the charger). One light blinking on charge means from 0% to 12% charge, you should never drop it down to 0%, the battery does like that and this may permanently damage the battery. If it is still on warranty send it in. One thing that used to work on older battery firmware was to hold down the power button onced pluged in the the charger, all the lights would come on then go to the charge level then let go of the button. Try it as you have nothing to lose.
robvalduga
