P3S range...
Is there any one that charges and will do the dbs install on the controller? I would rather have a pro do it.
+1 on the DBS for the Standard. Dont waste your money on the ARGTEK, i used one time then took it off and put the DBS panel on. You can add amps too when your ready for more!! And when thats not enough you can get a stronger 5.8 panel and pair it with the Maxxrange or Terminator....then boost that!!!! And when its still not enough you can go for the Terminator Extreme (add 5.8 panel)...
Sent from my SAMSUNG-SM-G730A using PhantomPilots mobile app
And if u still want more, well l guess u bye 1of these
Dbs will do it for you if you send them your RC. Once it's installed, just be aware that the antenna is pretty directional. You have to point the RC at the bird.
Where are you located? I'll help you out
Im in windham county CT
