P3P crashed... Here is my flight log
Bud,
How did you extract the motor stats (command, speed & load) from the file with CsvView. Is it because it is a litchi file and not a DJI GO app file? The DJI GO app TxT file loads OK but the DJI GO app DAT file will not load.
The .DAT resides on the Mavic itself, not the tablet. To see how to retrieve the .DAT look here.
Bud,
I assume those type DAT files are also on the P3S AC correct?
Yes, the .DAT is on the P3. Use that link to see how to retrieve them.
BTW, the P3S only records motorCommanded. It doesn't record speed or load.
DARN....... Load & Speed is good info in the case of a major incident. Oh well, "You get what you pay for"
Actually, you can do quite a bit with just motorCommanded. Usually, it's a broken or lost prop which results in 100% motorCommanded
In cases like these, I do wish DJI would add some form of an explanation of what happened.
Motor failure because of dirt in the bearings, or motor blew a piston, cracked cylinder head, radiator leaked all fluid, so motor overheated. Oh,sorry, that's my Ford small block.
rockymountaincaptures
