No Image Transmission Signal
I have the PP3 and it asked for a firmware update and when trying to install, it goes through the motion then I will get a steady "buzzing noise". Solid red instead of red/green. The firmware was unsuccessful. Also, I have the error message of No Image Transmission Signal. Everything was working fine prior to trying to update my firmware! Any ideas? Thanks!
Update the controller too? needs that. Reboot all.
After updating controller, re-flash the drone firmware. See if it completes normally.
Controller update is done through DJI go app.
If after all that done sucessfully, calibrate the IMU. Re-link may be needed.
I just stopped the firmware update..it has been updating for 2 hours..text files says aborted unsuccessful but the overall all status on the RC says normal. No image Transmission Signal is still their, black screen
And if you have one , try another sd card. It may be bad.
And just a question... . What firmware revision did it originally have? Did you jump a lot of revision levels?
Try reverting to 1.9.60. Phantom 3 Professional - Specs, FAQ, Tutorials, Downloads and DJI GO - DJI
Then try upgrade again. (You realize the .bin file needs to be in root sd card directry right?) Make sure it's unzipped. Only the bin file should be on the card. Try formatting card on pc. copy .bin to it, try again.
Yes
Im not sure what was previously in there but yes I tried numerous of FW and different levels
It may be " Bricked". Did you just buy it? Local store? return/replace if you can. If it's within its 12 month warranty period call DJI to replace it.
Yes
Will you please post your LOG_AB file. I'd like to see if it shows "device not detected" for modules 8 and 15 which could indicate that your gimbal board overheated during an extended FW update.
In case you or anyone doesnt know about these files, look on your SD card in the path below. The LOG_AB file shows the FW version of the assorted modules / components of your Phantom and if they did or did not need a change during a FW update. P3A and P3P have a couple of different components, so you may see "device not detected" for that reason or if a component is bad such as a gimbal board burning out.
Note that the LOG_AB file is a different txt file than you look at for the general overall "success" indication. Look on your SD card in the following path....
Some of the folders may be hidden:
MISC/LOG/
Then find your LOG_AB file: P3X_FW_LOG_AB.txt (for P3P) -or- P3S_FW_LOG_AB.txt (for P3A)
Reactions: GrammatonxXXxCleric
Does DJI go app show current firmware rev.? If latest firmware is flashed does it show latest level? (In about menu in app)
Oso always comes up with great info...
I purchased about 7 months ago..from an Ebay store brand new. Everything worked fine until I tried to update FW
But I'd do what Oso said.
Note that the LOG_AB file is a different txt file than you look at for the general overall "success" indication. Once you've done an update, look on your SD card in the following path....
MISC/LOG/
Im very new at this but I think this is what you are asking for
[00016363]Delete history success.
[00016663]========== remo-con disconnect. boot(15) ============
[00016751]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x45614b46].
[00016844]Packet upgrade start...
[00016935]Packet checking...
[00017031]Packet vlink 01.03.0020 <-> 01.01.0009.
[00017119]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 6).
[00017209]Packet upgrade failed at packet checking.
[00014610]========== remo-con disconnect. boot(15) ============
[00014700]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x45614b46].
[00014794]Packet upgrade start...
[00014884]Packet checking...
[00014978]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015069]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 1).
[00015161]Done.
[00015250]Version checking[1]...
[00015392][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015533][03 06][00] v2.4.14.5 -> v2.4.14.5
[00015639][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015792][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015927][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016061][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016215][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016372][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028968][15 00][00] device not detected.
[00029106][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029282][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029396][19 00][00] v255.255.255.254 -> v1.0.8.96
[00029490][01 00][00] v1.32.5432 -> v1.30.5036 need upgrade
[00029577][01 01][00] v1.30.5036 -> v1.30.5036
[00042173][08 00][00] device not detected.
[00042318][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042405]Packet upgrade failed at version checking.
[00014624]========== remo-con disconnect. boot(0) ============
[00014711]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x45614b46].
[00014804]Packet upgrade start...
[00014895]Packet checking...
[00014986]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015074]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 1).
[00015165]Done.
[00015253]Version checking[1]...
[00015379][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015613][03 06][00] v2.4.14.5 -> v2.4.14.5
[00015712][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015879][11 00][00] v1.8.0.0 -> v1.7.15.1
[00016028][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016162][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016313][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016448][12 03][00] v1.11.0.0 -> v1.10.0.0
[00029038][15 00][00] device not detected.
[00029163][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029354][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029468][19 00][00] v255.255.255.254 -> v1.0.8.96
[00029558][01 00][00] v1.32.5432 -> v1.30.5036 need upgrade
[00029651][01 01][00] v1.30.5036 -> v1.30.5036
[00042243][08 00][00] device not detected.
[00042369][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042464]Packet upgrade failed at version checking.
[00014626]========== remo-con disconnect. boot(15) ============
[00014713]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x45614b46].
[00014806]Packet upgrade start...
[00014899]Packet checking...
[00014993]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015081]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 1).
[00015175]Done.
[00015270]Version checking[1]...
[00015393][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015637][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015793][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015929][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016073][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016203][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016363][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028958][15 00][00] device not detected.
[00029099][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029261][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029380][19 00][00] v255.255.255.254 -> v1.0.8.96
[00029477][01 00][00] v1.32.5432 -> v1.30.5036 need upgrade
[00029564][01 01][00] v1.30.5036 -> v1.30.5036
[00042157][08 00][00] device not detected.
[00042279][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042369]Packet upgrade failed at version checking.
[00014732]========== remo-con disconnect. boot(15) ============
[00014971]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x21a9af62].
[00015065]Packet upgrade start...
[00015161]Packet checking...
[00015247]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015341]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00015430]Done.
[00015526]Version checking[1]...
[00015638][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015758][03 06][00] v2.4.14.5 -> v2.4.20.18 need upgrade.
[00015858][04 00][00] v1.48.0.0 -> v1.44.0.0
[00016038][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016218][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016314][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016482][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016627][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016752][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016902][12 03][00] v1.11.0.0 -> v1.10.0.0
[00029494][15 00][00] device not detected.
[00029651][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029827][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029946][19 00][00] v255.255.255.254 -> v1.0.8.96
[00030034][01 00][00] v1.32.5432 -> v1.30.5036
[00030125][01 01][00] v1.30.5036 -> v1.30.5036
[00042720][08 00][00] device not detected.
[00042827][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042922]Done.
[00045008]Waiting for user confirm...
[00055103]Timeout, start upgrade automatically.
[00055286]Firmware upgrading[1]...
[00055579][03 06] Firmware upgrade start...
[00416211][03 06] Firmware upgrade finished successfully.
[00416309]Done.
[00416405]Version checking[2]...
[00416521][03 05][00] v34.2.0.9 -> v34.2.0.9
[00416643][03 06][05] v2.4.20.18 -> v2.4.20.18
[00416750][04 00][00] v1.48.0.0 -> v1.44.0.0
[00416920][11 00][00] v1.8.0.0 -> v1.8.0.0
[00417078][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00417167][11 01][00] v1.8.0.0 -> v2.0.0.33
[00417320][12 00][00] v1.11.0.0 -> v1.10.0.0
[00417452][12 01][00] v1.11.0.0 -> v1.10.0.0
[00417587][12 02][00] v1.11.0.0 -> v1.10.0.0
[00417712][12 03][00] v1.11.0.0 -> v1.10.0.0
[00430413][15 00][00] device not detected.
[00430552][17 00][00] v1.1.1.7 -> v1.1.1.7
[00430727][17 01][00] v1.0.2.7 -> v1.0.2.7
[00430848][19 00][00] v255.255.255.254 -> v1.0.8.96
[00430945][01 00][00] v1.32.5432 -> v1.30.5036
[00431039][01 01][00] v1.30.5036 -> v1.30.5036
[00443634][08 00][00] device not detected.
[00443756][09 00][00] v3.0.0.10 -> v3.0.0.10
[00443845]Packet upgrade failed at version checking.
[00014816]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x21a9af62].
[00014907]Packet upgrade start...
[00014999]Packet checking...
[00015089]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015178]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 1).
[00015270]Done.
[00015357]Version checking[1]...
[00015490][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015625][03 06][00] v2.4.20.18 -> v2.4.14.5 need upgrade.
[00015721][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015891][11 00][00] v1.8.0.0 -> v1.7.15.1
[00016039][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016174][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016326][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016459][12 03][00] v1.11.0.0 -> v1.10.0.0
[00029050][15 00][00] device not detected.
[00029195][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029375][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029489][19 00][00] v255.255.255.254 -> v1.0.8.96
[00029584][01 00][00] v1.32.5432 -> v1.30.5036 need upgrade
[00029670][01 01][00] v1.30.5036 -> v1.30.5036
[00042264][08 00][00] device not detected.
[00042396][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042482]Done.
[00044576]Waiting for user confirm...
[00054662]Timeout, start upgrade automatically.
[00054845]Firmware upgrading[1]...
[00055112][03 06] Firmware upgrade start...
[00380584][03 06] Firmware upgrade finished successfully.
[00380673]Done.
[00380770]Version checking[2]...
[00380911][03 05][00] v34.2.0.9 -> v34.2.0.9
[00381051][03 06][05] v2.4.14.5 -> v2.4.14.5
[00381159][04 00][00] v1.48.0.0 -> v1.44.0.0
[00381511][11 00][00] v1.8.0.0 -> v1.7.15.1
[00381669][12 00][00] v1.11.0.0 -> v1.10.0.0
[00381831][12 01][00] v1.11.0.0 -> v1.10.0.0
[00381990][12 02][00] v1.11.0.0 -> v1.10.0.0
[00382143][12 03][00] v1.11.0.0 -> v1.10.0.0
[00394748][15 00][00] device not detected.
[00394893][17 00][00] v1.1.1.7 -> v1.1.1.7
[00395082][17 01][00] v1.0.2.7 -> v1.0.2.7
[00395190][19 00][00] v255.255.255.254 -> v1.0.8.96
[00395284][01 00][00] v1.32.5432 -> v1.30.5036 need upgrade
[00395374][01 01][00] v1.30.5036 -> v1.30.5036
[00407969][08 00][00] device not detected.
[00408071][09 00][00] v3.0.0.10 -> v3.0.0.10
[00408165]Packet upgrade failed at version checking.
[00030572]========== remo-con disconnect. boot(15) ============
[00030664]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x21a9af62].
[00030750]Packet upgrade start...
[00030845]Packet checking...
[00030934]Packet vlink 01.10.0090 <-> 01.10.0090.
[00031023]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00031110]Done.
[00031204]Version checking[1]...
[00031324][03 05][00] v34.2.0.9 -> v34.2.0.9
[00031445][03 06][00] v2.4.14.5 -> v2.4.20.28 need upgrade.
[00031551][04 00][00] v1.48.0.0 -> v1.48.0.0
[00031704][11 00][00] v1.8.0.0 -> v1.8.0.0
[00031870][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00031956][11 01][00] v1.8.0.0 -> v2.0.0.33
[00032098][12 00][00] v1.11.0.0 -> v1.11.0.0
[00032258][12 01][00] v1.11.0.0 -> v1.11.0.0
[00032395][12 02][00] v1.11.0.0 -> v1.11.0.0
[00032519][12 03][00] v1.11.0.0 -> v1.11.0.0
[00045108][15 00][00] device not detected.
[00045255][17 00][00] v1.1.1.7 -> v1.1.1.7
[00045445][17 01][00] v1.0.2.7 -> v1.0.2.7
[00045555][19 00][00] v255.255.255.254 -> v1.0.8.96
[00045642][01 00][00] v1.32.5432 -> v1.32.5432
[00045734][01 01][00] v1.30.5036 -> v1.32.5432 need upgrade
[00058321][08 00][00] device not detected.
[00058435][09 00][00] v3.0.0.10 -> v3.0.0.10
[00058527]Done.
[00060614]Waiting for user confirm...
[00070804]Timeout, start upgrade automatically.
[00070984]Firmware upgrading[1]...
[00071170][01 01] Firmware upgrade start...
[00101502][01 01] Firmware upgrade finished successfully.
[00101791][03 06] Firmware upgrade start...
[00470803][03 06] Firmware upgrade finished successfully.
[00470892]Done.
[00470987]Version checking[2]...
[00471123][03 05][00] v34.2.0.9 -> v34.2.0.9
[00471283][03 06][05] v2.4.20.28 -> v2.4.20.28
[00471391][04 00][00] v1.48.0.0 -> v1.48.0.0
[00471562][11 00][00] v1.8.0.0 -> v1.8.0.0
[00471743][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00471836][11 01][00] v1.8.0.0 -> v2.0.0.33
[00471971][12 00][00] v1.11.0.0 -> v1.11.0.0
[00472122][12 01][00] v1.11.0.0 -> v1.11.0.0
[00472286][12 02][00] v1.11.0.0 -> v1.11.0.0
[00472439][12 03][00] v1.11.0.0 -> v1.11.0.0
[00485026][15 00][00] device not detected.
[00485168][17 00][00] v1.1.1.7 -> v1.1.1.7
[00485348][17 01][00] v1.0.2.7 -> v1.0.2.7
[00485457][19 00][00] v255.255.255.254 -> v1.0.8.96
[00485548][01 00][00] v1.32.5432 -> v1.32.5432
[00485641][01 01][05] v1.32.5432 -> v1.32.5432
[00498228][08 00][00] device not detected.
[00498339][09 00][00] v3.0.0.10 -> v3.0.0.10
[00498427]Packet upgrade failed at version checking.
[00014573]========== remo-con disconnect. boot(15) ============
[00014665]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x21a9af62].
[00014752]Packet upgrade start...
[00014847]Packet checking...
[00014936]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015028]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00015113]Done.
[00015206]Version checking[1]...
[00015332][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015456][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015561][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015712][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015876][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015963][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016081][12 00][00] v1.11.0.0 -> v1.11.0.0
[00016237][12 01][00] v1.11.0.0 -> v1.11.0.0
[00016533][12 02][00] v1.11.0.0 -> v1.11.0.0
[00016666][12 03][00] v1.11.0.0 -> v1.11.0.0
[00029253][15 00][00] device not detected.
[00029403][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029561][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029661][19 00][00] v255.255.255.254 -> v1.0.8.96
[00029757][01 00][00] v1.32.5432 -> v1.32.5432
[00029849][01 01][00] v1.32.5432 -> v1.32.5432
[00042444][08 00][00] device not detected.
[00042562][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042651]Packet upgrade failed at version checking.
[00014756]========== remo-con disconnect. boot(15) ============
[00014845]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x21a9af62].
[00014940]Packet upgrade start...
[00015038]Packet checking...
[00015131]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015222]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 6).
[00015309]Packet upgrade failed at packet checking.
[00012774]========== remo-con disconnect. boot(15) ============
[00012868]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x21a9af62].
[00012962]Packet upgrade start...
[00013060]Packet checking...
[00013156]Packet vlink 01.09.0060 <-> 01.08.0080.
[00013243]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00013338]Done.
[00013426]Version checking[1]...
[00013570][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013705][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013811][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013985][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014145][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014231][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014398][12 00][00] v1.11.0.0 -> v1.10.0.0
[00014533][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014685][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014845][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027434][15 00][00] device not detected.
[00027593][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027775][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027885][19 00][00] v255.255.255.254 -> v1.0.8.96
[00027972][01 00][00] v1.32.5432 -> v1.30.5036
[00028161][01 01][00] v1.32.5432 -> v1.30.5036
[00040751][08 00][00] device not detected.
[00040865][09 00][00] v3.0.0.10 -> v3.0.0.10
[00040952]Packet upgrade failed at version checking.
[00012583]========== 2017.01.02 16:30:55. boot(15) ============
[00012671]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x21a9af62].
[00012758]Packet upgrade start...
[00012852]Packet checking...
[00012941]Packet vlink 01.09.0060 <-> 01.08.0080.
[00013033]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00013121]Done.
[00013215]Version checking[1]...
[00013339][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013466][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013569][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013762][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013943][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014034][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014210][12 00][00] v1.11.0.0 -> v1.10.0.0
[00014372][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014505][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014657][12 03][00] v1.11.0.0 -> v1.10.0.0
[00027245][15 00][00] device not detected.
[00027385][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027546][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027647][19 00][00] v255.255.255.254 -> v1.0.8.96
[00027734][01 00][00] v1.32.5432 -> v1.30.5036
[00027826][01 01][00] v1.32.5432 -> v1.30.5036
[00040411][08 00][00] device not detected.
[00040522][09 00][00] v3.0.0.10 -> v3.0.0.10
[00040607]Packet upgrade failed at version checking.
[00015207]========== remo-con disconnect. boot(15) ============
[00015299]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xda5db32f].
[00015393]Packet upgrade start...
[00015490]Packet checking...
[00015584]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015677]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00015771]Done.
[00015866]Version checking[1]...
[00015995][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016115][03 06][00] v2.4.20.28 -> v2.4.20.18
[00016221][04 00][00] v1.48.0.0 -> v1.44.0.0
[00016534][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016694][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016791][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016929][12 00][00] v1.11.0.0 -> v1.10.0.0
[00017068][12 01][00] v1.11.0.0 -> v1.10.0.0
[00017207][12 02][00] v1.11.0.0 -> v1.10.0.0
[00017343][12 03][00] v1.11.0.0 -> v1.10.0.0
[00029942][15 00][00] device not detected.
[00030083][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030272][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030386][19 00][00] v255.255.255.254 -> v1.0.8.96
[00030482][01 00][00] v1.32.5432 -> v1.30.5036
[00030580][01 01][00] v1.32.5432 -> v1.30.5036
[00043184][08 00][00] device not detected.
[00043304][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043400]Packet upgrade failed at version checking.
[00015204]========== remo-con disconnect. boot(15) ============
[00015298]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xda5db32f].
[00015388]Packet upgrade start...
[00015484]Packet checking...
[00015580]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015674]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00015771]Done.
[00015860]Version checking[1]...
[00015988][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016107][03 06][00] v2.4.20.28 -> v2.4.20.28
[00016208][04 00][00] v1.48.0.0 -> v1.48.0.0
[00016367][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016527][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016620][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016766][12 00][00] v1.11.0.0 -> v1.11.0.0
[00016896][12 01][00] v1.11.0.0 -> v1.11.0.0
[00017038][12 02][00] v1.11.0.0 -> v1.11.0.0
[00017180][12 03][00] v1.11.0.0 -> v1.11.0.0
[00029778][15 00][00] device not detected.
[00029922][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030097][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030217][19 00][00] v255.255.255.254 -> v1.0.8.96
[00030311][01 00][00] v1.32.5432 -> v1.32.5432
[00030400][01 01][00] v1.32.5432 -> v1.32.5432
[00042994][08 00][00] device not detected.
[00043257][09 00][00] v3.0.0.10 -> v3.0.0.10
[00043351]Packet upgrade failed at version checking.
mactechnic
