I just got a P2 v2 brand new... Took it out for a test flight (I had a P1 before)... Takes off fine and hovers ok but when I accelerate straight up its like the two left motors have more lift and it goes up but to the left. When I let off the stick it hovers and drifts back to where it would of been if it was straight up... I did a basic cal on the IMU ...but it still does it....
There is no gadgets or gimbal on it...it is completely stock...
Make sure you do a compass calibration every time you go to a new place to fly. it is very important and make sure your cell phone inst close while doing so. once your phantom is on let is sift for a mite and sort itself out then switch from gps to atto on the right hand switch 5 times until lights go solid yellow. rotate your phantom then 360 degrees until light goes solid green i believe. then tile forward to 90 degrees and rotate the phantom all the way around and it should go back to flashing green or yellow depending on what mode you are in. Try and make a small checklist for every time you fly what you need to do. Your phantom will treat you kindly if you operate it properly. Have fun and hope this helped
Doing the compass calibration every time go to a new location is not necessary. Now if you were go a location 100 miles or more away I would do a compass cal. But surely not every time I change location which I often do when out filming..
UPDATE: I returned the original bird and got a new replacement today...test flight showed it to fly just fine...just like it should...never did find out why the original one would behave that way...However the one I did receive today I did not do an firmware upgrade...just a compass calibrate and it flew great. Ill take it out this evening again...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
