Hello guys i might be not the only one having a GoPro 3+ BE with broken mini USB? The very fragile ribbon connector did not convince me from the beginning, but the 10-pin mini USB gave up even before the ribbon... I opened the GoPro, but no chance to solder.
Here is the story how i solved the problem:
1. Get a video board like this http://www.getfpv.com/gopro-video-board-live-video-out-charge.html. It connects to the rear 30-pin flat port.
2. Remove the little aluminium plate (placeholder) sitting inside the H3-3D by unscrewing the two phillips screws.
3. Use a Dremel or similar tool to mill out the back of the H3-3D, so that the video board can easily pass through the cut-off. Make sure the video board is not obstructed by the aluminium frame of the gimbal.
4. Connect the video board to the GoPro and place the cam inside the gimbal. If the plastic cover of the usb / hdmi compartment lines up with the frame of the gimbal, the GoPro sits comfortable.
5. Mount the gimbal to your phantom.
6. Check the GC of the gimbal, it might have changed after removing some weight from the frame. I re-balanced my gimbal using a very little velcro with a piece of plastic eraser sticked to it (approximately 3mm thick, use a cutter knife to adjust the weight). Try out the proper weight, so that the gimbal is balanced properly.
7. Use some pvc electric tape to cover the back. This serves just as a dust protection.
The GoPro can easily be charged through the 3-pin servo connector that comes from the video board. I soldered a usb cable to a servo female connector to charge the GoPro while it is still mounted in the Phantom. To get the data from the micro sd card - remove the card from the cam and read out directly into your computer.
Enjoy! HTH
Enjoy! HTH
