Can anyone confirm if under "Mission Setting/Finish Action=Land" will the aircraft actually land itself on the ground or will it hover a few feet from the ground? I'm also assuming this would use the recorded home point to do so?
Yes, it will land at that location.Can anyone confirm if under "Mission Setting/Finish Action=Land" will the aircraft actually land itself
The home point has nothing to do with the "Finish Action", "Land". It will "RTH" if you set that as your finish action.I'm also assuming this would use the recorded home point to do so?
Interesting and clever at the same time! Always seems to be a work-around with these issues.
Does anyone have any suggestions as to when the last way point is reached to have the aircraft desend faster than 1 mph? I've tried to adjust the speed but no luck yet.
Thanks for all the replies and suggestions
