- Joined
- May 2, 2016
- Messages
- 34
- Reaction score
- 0
- Age
- 64
Do you think that this firmware is the same there is on lightbridge for boot? Maybe there are also some DJI code on Nand. And DJI don't do help at all...
Yes,I mean this. Not only code, but maybe some setting (like U-boot environment).of course it is possible that the flash contains more data than what we have in our files. for this reason we need a full backup of the flash, from a working LB.
DM365_432 DDR 340 initialization passed!
Booting TI User Boot Loader
UBL Version: 1.65
UBL Flashtype: NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
DONE
Jumping to entry point at 0x81080000.
DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Uboot Checksum:0x3A4D8A01
Actua Checksum:0x3A4D8A01
BootMode = NAND
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2014-05-30 6:44:26 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4034816 Bytes = 3.8 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-GSPv2-Kernel-1.0-rc3(2014-05-30 14:45)
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@dji) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #8 PREEMPT Fri May 30 14:44:25 HKT 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44456KB available (3644K code, 446K data, 116K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.030000] EVM: tvp5146 SD video input
[ 0.110000] bio: create slab <bio-0> at 0
[ 0.110000] DM365 IPIPE initialized in Continuous mode
[ 0.120000] SCSI subsystem initialized
[ 0.120000] usbcore: registered new interface driver usbfs
[ 0.120000] usbcore: registered new interface driver hub
[ 0.120000] usbcore: registered new device driver usb
[ 0.130000] vpss vpss: dm365_vpss vpss probed
[ 0.130000] vpss vpss: dm365_vpss vpss probe success
[ 0.130000] dm365_afew_hw_init
[ 0.140000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.140000] VPBE Encoder Initialized
[ 0.140000] cfg80211: Using static regulatory domain info
[ 0.140000] cfg80211: Regulatory domain: US
[ 0.140000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.140000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.140000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.140000] cfg80211: Calling CRDA for country: US
[ 0.140000] LogicPD encoder initialized
[ 0.140000] Switching to clocksource timer0_1
[ 0.150000] musb_hdrc: version 6.0, pio, host, debug=0
[ 0.170000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[ 0.170000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.170000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.170000] usb usb1: configuration #1 chosen from 1 choice
[ 0.170000] hub 1-0:1.0: USB hub found
[ 0.170000] hub 1-0:1.0: 1 port detected
[ 0.170000] NET: Registered protocol family 2
[ 0.170000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.170000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.170000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.170000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.170000] TCP reno registered
[ 0.170000] NET: Registered protocol family 1
[ 0.170000] RPC: Registered udp transport module.
[ 0.170000] RPC: Registered tcp transport module.
[ 0.170000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.180000] kfile init
[ 0.180000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.180000] msgmni has been set to 86
[ 0.190000] alg: No test for stdrng (krng)
[ 0.190000] io scheduler noop registered (default)
[ 0.220000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
[ 0.230000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuffer size 8100KB
[ 0.230000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.250000] davincifb davincifb.0: dm_osd1_fb: Initial window configuration is invalid.
[ 0.250000] davincifb davincifb.0: dm_osd1_fb: 1920x1080x4@0,0 with framebuffer size 4050KB
[ 0.250000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.310000] venc off init
[ 0.310000] hdmi status init
[ 0.310000] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 0.310000] DM365 IPIPEIF probed
[ 0.320000] imp serializer initialized
[ 0.320000] davinci_previewer initialized
[ 0.320000] davinci_resizer initialized
[ 0.320000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.330000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.810000] console [ttyS0] enabled
[ 0.810000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.820000] brd: module loaded
[ 0.820000] at24 1-0050: 32768 byte 24c256 EEPROM (writable)
[ 0.900000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.910000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.920000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.920000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.930000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 0.940000] 0x000000000000-0x000008000000 : "all"
[ 0.950000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 0.960000] UBI: attaching mtd2 to ubi0
[ 0.960000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 0.970000] UBI: logical eraseblock size: 126976 bytes
[ 0.970000] UBI: smallest flash I/O unit: 2048
[ 0.980000] UBI: sub-page size: 512
[ 0.980000] UBI: VID header offset: 2048 (aligned 2048)
[ 0.990000] UBI: data offset: 4096
[ 1.120000] usb 1-1: new high speed USB device using musb_hdrc and address 2
[ 1.270000] usb 1-1: configuration #1 chosen from 1 choice
[ 1.270000] hub 1-1:1.0: USB hub found
[ 1.280000] hub 1-1:1.0: 2 ports detected
[ 1.510000] UBI: attached mtd2 to ubi0
[ 1.510000] UBI: MTD device name: "filesystem"
[ 1.520000] UBI: MTD device size: 113 MiB
[ 1.520000] UBI: number of good PEBs: 904
[ 1.530000] UBI: number of bad PEBs: 0
[ 1.530000] UBI: max. allowed volumes: 128
[ 1.540000] UBI: wear-leveling threshold: 4096
[ 1.540000] UBI: number of internal volumes: 1
[ 1.550000] UBI: number of user volumes: 1
[ 1.550000] UBI: available PEBs: 0
[ 1.560000] UBI: total number of reserved PEBs: 904
[ 1.560000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.570000] UBI: max/mean erase counter: 63/1
[ 1.570000] UBI: image sequence number: 1092381712
[ 1.580000] UBI: background thread "ubi_bgt0d" started, PID 349
[ 1.590000] console [netcon0] enabled
[ 1.590000] netconsole: network logging started
[ 1.590000] Initializing USB Mass Storage driver...
[ 1.600000] usbcore: registered new interface driver usb-storage
[ 1.610000] USB Mass Storage support registered.
[ 1.610000] usbcore: registered new interface driver usbtest
[ 1.620000] i2c /dev entries driver
[ 1.620000] Linux video capture interface: v2.00
[ 1.630000] ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
[ 1.640000] ths7303 1-002c: ths7303 write failed
[ 1.640000] ths7303: probe of 1-002c failed with error -121
[ 1.650000] tvp5150_init
[ 1.650000] vpfe_init
[ 1.650000] vpfe-capture: vpss clock vpss_master enabled
[ 1.660000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.670000] vpfe-capture vpfe-capture: video device registered
[ 1.670000] tvp5150_probe
[ 1.680000] tvp5150 1-005d: tvp5150 1-005d decoder driver registered !!
[ 1.680000] vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
[ 1.690000] vpfe-capture vpfe-capture: v4l2 sub device cat6023 register fails
[ 1.700000] vpfe_register_ccdc_device: DM365 ISIF
[ 1.700000] DM365 ISIF is registered with vpfe.
[ 1.710000] Trying to register davinci display video device.
[ 1.720000] layer=c17f7000,layer->video_dev=c17f7164
[ 1.720000] Trying to register davinci display video device.
[ 1.730000] layer=c17f7400,layer->video_dev=c17f7564
[ 1.740000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[ 1.740000] watchdog watchdog: heartbeat 1 sec
[ 1.750000] TCP cubic registered
[ 1.750000] NET: Registered protocol family 17
[ 1.760000] lib80211: common routines for IEEE802.11 drivers
[ 1.760000] ksocket init
[ 1.790000] Clocks: disable unused mmcsd0
[ 1.790000] Clocks: disable unused mmcsd1
[ 1.790000] Clocks: disable unused spi0
[ 1.790000] Clocks: disable unused spi1
[ 1.790000] Clocks: disable unused spi2
[ 1.790000] Clocks: disable unused spi3
[ 1.790000] Clocks: disable unused spi4
[ 1.790000] Clocks: disable unused pwm0
[ 1.790000] Clocks: disable unused pwm1
[ 1.790000] Clocks: disable unused pwm2
[ 1.790000] Clocks: disable unused pwm3
[ 1.790000] Clocks: disable unused timer1
[ 1.790000] Clocks: disable unused timer3
[ 1.790000] Clocks: disable unused emac
[ 1.790000] Clocks: disable unused voice_codec
[ 1.790000] Clocks: disable unused asp0
[ 1.790000] Clocks: disable unused rto
[ 1.790000] Clocks: disable unused mjcp
[ 1.870000] nnnn===0
[ 1.870000] davinci_emac_probe: using random MAC addr: 46:40:56:47:74:4c
[ 1.880000] emac-mii: probed
[ 1.920000] UBIFS: recovery needed
[ 1.970000] UBIFS: recovery completed
[ 1.970000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.980000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 1.980000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 1.990000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.000000] UBIFS: default compressor: lzo
[ 2.000000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.010000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 2.010000] Freeing init memory: 116K
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>GSPv2<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Filesystem Product Vesion : DJI-GSPv2-Filesystem-1.0-rc3(2014-06-05)
Runing /etc/init.d/rcS
[ 3.800000] CMEMK module: built on Jan 22 2014 at 14:52:00
[ 3.820000] Reference Linux version 2.6.32
[ 3.820000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 3.840000] allocated heap buffer 0xc7000000 of size 0x4400000
[ 3.870000] heap fallback enabled - will try heap if pool buffer is not available
[ 3.870000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 3.880000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 3.890000] cmemk initialized
[ 3.920000] IRQK module: built on Jan 22 2014 at 14:52:01
[ 3.940000] Reference Linux version 2.6.32
[ 3.940000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 3.960000] irqk initialized
[ 4.010000] EDMAK module: built on Jan 22 2014 at 14:52:02
[ 4.010000] Reference Linux version 2.6.32
[ 4.030000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 4.700000] usb 1-1.1: new high speed USB device using musb_hdrc and address 3
[ 4.830000] usb 1-1.1: configuration #1 chosen from 1 choice
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
sulogin: no password entry for root
umount: can't umount /mnt/usb: No such file or directory
login[491]: root login on 'ttyS0'
rmdir: '/mnt/usb': No such file or directory
#Process /etc/profile...
root@Dji-Pro:~#
USBClient version 1.0.23
ReadSize = 2048 Timeout = 90
init libusb successed!!!
!!!!!!!!!!!!!!!!!!!!!!! open 68013 succeed VENDOR_ID = 0x0547
Claiming libusb_claim_interface 68013 successed
usbmuxd_subscribe OK OK
watchdog timeout:5
latency1:33332
latency2:33000
latency3:30000
displaybuffnum1:4
displaybuffnum2:9
start decode stream from 68013
decode init ok, main thread exit
Osd_Init_Font succeed
[ 9.660000] pinmux1:0x00185555
[ 9.660000] pinmux4:0x1155fdff
[ 9.720000] pinmux1:0x00185555
[ 9.720000] pinmux4:0x1155fdff
[ 9.830000] pinmux1:0x00185555
[ 9.830000] pinmux4:0x1155fdff
[ 9.890000] pinmux1:0x00185555
[ 9.890000] pinmux4:0x1155fdff
[ 9.950000] pinmux1:0x00185555
[ 9.950000] pinmux4:0x1155fdff
[ 11.980000] PCLK = 0 -> 0
[ 11.980000] HTotal = 0 -> 1650
[ 11.980000] VTotal = 0 -> 750
[ 11.990000] ScanMode = I -> P
[ 12.000000] PCLK = 0,(1650x750) PROGRESS CHANGE MODE
[ 12.000000] VIC = 4
root@Dji-Pro:~#
root@Dji-Pro:~#
Created: 2014-11-27 10:20:54 UTC
Data Size: 4032928 Bytes = 3.8 MiB
