iPad Mini clamp
Frederick, MD, USA
I searched but did not find a specific post on this subject.
I want to use my iPad Mini for my FPV monitor, but the OEM clamp does not appear to reach to hold the Mini. Is there an alternative clamp (or a way of extending the OEM clamp) without damaging the mount or original clamp and holding the Mini securely?
I bought this:
http://www.ebay.com/itm/360877058149
Hope this helps:
Here are some pics with full size iPad, but will fit mini also
Take care, fly safe!
Jerry,
When I went to the Ebay link you provided, I didn't see a mount with the OEM clamp interface (ball-socket), how did you connect the aftermarket clamp to the controller?
Thanks,
Tom
Try these places YouTube search for Ben7seven7 he has several videos including one to add many different tablets the other place to look for a much simpler and cheaper method vimeo.com search for Bill Hower videos he has a very cheap but good method
slothead said:
That looks good Cougar, but could you explain what all the pieces are and where I could get them?
Thanks,
Tom
Hi Tom,
Just reversed the handle on the transmitter, bought 2 items (links below) cut and glued the OEM phone holder to the back of the Mini mount and painted the parts. Photo of the back so you can see better is below as well.
iPad Mini holder:
http://www.ebay.com/itm/New-Black-360-I ... 0909286887
Sun Shade
http://www.amazon.ca/Patec®-Satnav-Universal-Magellan-RoadMate/dp/B00DGNZFHG
Hello,
You simply unscrew ball mount from phone holder, then do the same on new mount,
They are the same size, then swap the 2, 5 minutes tops to install !
Super simple! You will need a sun shade, I don't use mine, because is too hard to see in sunlight!
Nice thing about this mount, you can always switch back!
Hope this helps!
:D
canadiansauna
