Internal Blinking Light & Camera Issue
East Texas
I cant figure out why my camera is facing the wrong direction nor can I figure out what the blinking light is inside my p3p
The outer shell was recently replaced and the gimble was as well. below are pics as well as a copy of the .txt file from the "hidden" log folder.
Also in the text files one line says it detected multiple versions...that has been corrected
20160629_190241[1].jpg 20160629_181732[1].jpg 20160629_190412[1].jpg 20160629_181743[1].jpg
*****FROM SD CARD*****
***** P3X_FW_RESULT_AB.txt*****
_______________________________________________________
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.06.10 13:17:42 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2016.06.11 18:33:37 =====================
Result: Abort.
Result: Abort.
========== 2014.01.01 00:01:52 remo-con disconnect======
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Packet: P3X_FW_V01.08.0080.bin, P3X_FW_V01.09.0060.bin
Result: Forbidden.
Multiple version firmware bin files are detected. Please delete the redundant bin file.
Packet: P3X_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2016.06.14 14:34:00 =====================
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
========== 2016.06.15 21:09:19 =====================
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.06.17 23:46:00 =====================
Result: Abort.
Result: Abort.
========== 2016.06.18 06:34:47 =====================
Result: Abort.
========== 2016.06.18 06:51:04 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.06.18 07:46:09 =====================
Result: Abort.
========== 2016.06.18 12:53:55 =====================
Result: Abort.
Result: Abort.
========== 2016.06.18 23:51:46 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.06.19 11:59:58 =====================
Result: Abort.
========== 2016.06.19 12:18:59 =====================
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
========== 2016.06.20 00:08:30 =====================
Result: Abort.
========== 2016.06.20 00:16:08 =====================
Result: Abort.
========== 2016.06.20 00:27:30 =====================
Result: Abort.
========== 2016.06.20 00:46:53 =====================
Result: Abort.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2016.06.20 01:14:58 =====================
Result: Abort.
Result: Abort.
========== 2016.06.20 13:17:55 =====================
Result: Abort.
========== 2016.06.26 16:02:16 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:01:17 remo-con disconnect======
Result: Abort.
Result: Abort.
  • P3X_FW_LOG_AB.txt
*****From LOG file*****
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Corrupted.
Result: Forbidden.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
is red light on the gimbal solid or blinking?
if blinking it's because you took the sd card out, if solid then something is not right
What causes the camera to sit sideways like that, even though you've done a camera calibration in the app? I have a unit that does that!
on the yaw arm motor shaft there is a magnet that is suppose to be bolted on the shaft itself and it rotates sometimes causing this.
the easy fix is to take the gimbal off, grab the top motor (yaw) with pliers and physically rotate the whole thing the opposite way.
so when you do that shaft will rotate inside with the magnet on the shaft. if that doesn't work it means the magnet on the shaft is loose (just another DJI's "brilliant" idea :) ) and replace the yaw motor.
Reactions: dirtybum
Thank You...Will advise
