The 3 light flash is normal at every start up. Please download and read the manual.anyone know about the 3 light flash???
The red..green...yellow flashing is normal on start up. the AC is in diagnostic mode. It should only be that way for a short amount of time. Then the rear lights should flash yellow while the AC warms up. If your getting the 3 color flash for 10 minutes, something is likely not right.front solid red back 3 light
beep beep 5-10 min same?
normal
Okay...Is your remote control on?drone is not passing self check.. lights not turning yellow
Yep...you're good to go.upgrading firmware// on remote then asked to re calibrate ...so i followed instruction and am re calibrating. now
3 light just stopped
now green two flash!!
happy Everything! thanks for the replies! i believe I'm good to go
