- Joined
- Aug 29, 2014
- Messages
- 21
- Reaction score
- 2
Hi,
Over the past week i have finally got onto some long planned upgrades for my vision plus.
aluminium foil gps mod.
stage 3 fpvlr
flytrex live 3g
the flytrex and foil mod worked great.
I am having some trouble and having really bad results with the 2.4ghz video connection.
I am not sure if i have done something wrong, or if i have damaged something during the install process.
I am losing connection at very close distances, like 20m away at some times. i have tried all the different resolution and frame rate settings. lower ones are working better, but still not use-able . Much Much worse than before the mod.
I have since removed the foil mod to make sure that was not causing an issue. No change.
I have checked all the pigtail cables, and that all connectors are tight and male to female. Surely if ONE was loose i would still get a reasonable connection from the other.
I also went through and made sure there were no kinks or hard angles on the pigtails. The connectors in the range extender are not and have not been touching the metal box.
I have tried reseting and re binding the extender.
My thoughts would be that something is wrong with either the range extender of the Wifi module. i am just not sure how i can isolate which one could be the problem.
When doing the mod on the range extender i accidentally flicked the power switch on, when there were no antenna connected. It would have only been on for about 2 seconds at most. Could this have damaged the device severely?
please check the pics and let me know if you see anything that looks worrying.
The device i am using is a Samsung tab s 8.4
Thanks for any help anyone might be able to provide.
Chris
stage 3 fpvlr
flytrex live 3g
Chris
