ESC Status Error... HELP!!!
Hi Oso, thanks very much for that info - it says I need to reinstall the DJI GO app, to lift the height/distance restrictions, which I have done.
I will try flying again tomorrow, but fingers crossed that will hopefully have fixed it.
Actually, that post says that some have had to reinstall the app. Most people are able to remove the restrictions by doing what it says first which is to log out and log in.
Good luck.
It does indeed say that, but I re-installed the app anyway. It lifted the flight restrictions, but since the FW upgrade I'm now getting issues that other pilots are reporting, namely 1) the video feed from the aircraft to the RC keeps dropping out, and it lags slightly. And 2) my iPad2 mini sometimes reports that the CPU is at maximum capacity when running the DJI GO app. My P3P also reported today that the battery was "critically low" when it was actually at 67% (the critical level is set to 12%)
I'm tempted to downgrade back to a known good FW, but I've read that DJI have blocked that possibility, so I guess I'm stuck with it. If the only purpose of this FW upgrade was
(1) to upgrade the NFZ management,
(2) to correct an ESC self-test error (which I didn't suffer from)
(3) to impose flight restrictions which can immediately be dispensed with,
then I can't see why it was required.
Does anyone know if it is possible to revert to a known good FW?
Thank you all!
Guys,
If you are having an ESC Error after a firmware update, please call us so that we can send you the firmware version 1.11.30. You can copy this via your SD card and update your aircraft. This will resolve the issue!!.. If this fails repeatedly please call us and send the log file for us to find a resolution for you.
Just took mine out of box last night, took out today and I am getting the ESC Status Error, also getting battery error and controller is at 4 lights and drone 3 lights.
Guys,
Hi Raul, I'm having issues with my ESC as well. Can you please send me the update?
Thank you,
Brian
I am having ESC Error at take off on P3A. I replaced the shell, and updated the controller. Now I get ESC Error. Camera gimbal works fine. Powers up and connects perfect, it just will not take off with the error.
Please help, the download links in this thread are not working
[QUOTE = "Raul.Flaga, post: 1261944, member: 98878"] Chicos,
Si tiene un error ESC después de una actualización de firmware, llámenos para que podamos enviarle la versión de firmware 1.11.30. Puede copiar esto a través de su tarjeta SD y actualizar su avión. ¡Esto resolverá el problema! .. Si esto falla repetidamente, llámenos y envíe el archivo de registro para que podamos encontrar una resolución para usted. [/ QUOTE]
Saludos Raúl y a todos los foreros Mi Nombre es Rodrigo, el problema es de un P3P y aunque el post es un poco antiguo me gustaria que me ayudes por favor con el problema de ""esc status error"" ya instale el firmware P3X_FW_V01.11.0030.bin y volvió funcionar pero de forma intermitente a veces funcionaba y otras volvía a mostrar el error pero de pronto dejo de funcionar nuevamente. no se que archivo necesitas pero te dejo los siguientes.
T Agradezco de antemano.
  • P3X_FW_LOG_AB.txt
  • P3X_FW_RESULT_AB.txt
Guys,
Hey Raul can you email me this version too please asap. Thanks in advance!
See post #16, you can download it from the link. It is not official, beware, see post #15, #22, read the full thread before doing any fw upgrade.
One more here with the same problem. Just downloaded 1.11.30 and will try to install it later. Hope it fixes the problem!
Guys,
Hi can you pls, send me that firmware version? THX
[00029402]Delete history success.
[00030014]========== remo-con disconnect. boot(15) ============
[00030107]Packet [C:\P3X_FW_V01.11.0030.bin] detected, card sn [0x2853876c].
[00030210]Packet upgrade start...
[00030303]Packet checking...
[00030400]Packet vlink 01.11.0030 <-> 01.11.0020.
[00030488]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 0).
[00030581]Done.
[00030669]Version checking[1]...
[00030809][03 06][00] v2.4.20.50 -> v2.4.20.50
[00030949][03 05][00] v34.2.0.9 -> v34.2.0.9
[00031054][04 00][00] v1.48.0.0 -> v1.48.0.0
[00031229][11 00][00] v1.8.0.0 -> v1.8.0.0
[00031410][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00031501][11 01][00] v1.8.0.0 -> v2.0.0.33
[00031653][12 00][00] v1.13.0.0 -> v1.13.0.0
[00031806][12 01][00] v1.13.0.0 -> v1.13.0.0
[00031989][12 02][00] v1.13.0.0 -> v1.13.0.0
[00032149][12 03][00] v1.13.0.0 -> v1.13.0.0
[00032337][15 00][00] v1.1.2.0 -> v1.1.2.0
[00032473][17 00][00] v1.1.1.7 -> v1.1.1.7
[00032658][17 01][00] v1.0.2.7 -> v1.0.2.7
[00032784][19 00][00] v1.0.8.96 -> v1.0.8.96
[00032881][01 00][00] v1.32.5432 -> v1.32.5432
[00032976][01 01][00] v1.32.5432 -> v1.32.5432
[00033086][08 00][00] v0.13.0.7 -> v0.13.0.7
[00033207][09 00][00] v4.1.0.0 -> v4.1.0.0
[00033297]Packet upgrade cancelled at version checking.
[00013326]========== remo-con disconnect. boot(15) ============
[00013416]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x2853876c].
[00013510]Packet upgrade start...
[00013605]Packet checking...
[00013701]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013795]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 7).
[00013886]Packet upgrade failed at packet checking.
[00012687]========== remo-con disconnect. boot(15) ============
[00012783]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x2853876c].
[00012870]Packet upgrade start...
[00012967]Packet checking...
[00013061]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013152]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 7).
[00013393]Packet upgrade failed at packet checking.
[00012727]========== remo-con disconnect. boot(15) ============
[00012815]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x2853876c].
[00012906]Packet upgrade start...
[00012998]Packet checking...
[00013094]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013191]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 7).
[00013280]Packet upgrade failed at packet checking.
[00013351]========== remo-con disconnect. boot(15) ============
[00013443]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x2853876c].
[00013538]Packet upgrade start...
[00013631]Packet checking...
[00013724]Packet vlink 01.10.0090 <-> 01.10.0090.
[00013818]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 6).
[00013905]Packet upgrade failed at packet checking.
[00013261]========== 2018.06.08 23:07:23. boot(15) ============
[00013351]Packet [C:\P3X_FW_V01.11.0030.bin] detected, card sn [0x2853876c].
[00013449]Packet upgrade start...
[00013551]Packet checking...
[00013642]Packet vlink 01.11.0030 <-> 01.11.0020.
[00013735]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 0).
[00013824]Done.
[00013921]Version checking[1]...
[00014054][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014172][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014286][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014452][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014635][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014729][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014893][12 00][00] v1.13.0.0 -> v1.13.0.0
[00015026][12 01][00] v1.13.0.0 -> v1.13.0.0
[00015187][12 02][00] v1.13.0.0 -> v1.13.0.0
[00015345][12 03][00] v1.13.0.0 -> v1.13.0.0
[00015549][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015702][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015886][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015986][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016084][01 00][00] v1.32.5432 -> v1.32.5432
[00016173][01 01][00] v1.32.5432 -> v1.32.5432
[00016297][08 00][00] v0.13.0.7 -> v0.13.0.7
[00016566][09 00][00] v4.1.0.0 -> v4.1.0.0
[00016657]Packet upgrade cancelled at version checking.
[00012549] ========== قطع الاتصال عن بعد. التمهيد (15) =============
[00012633] تم اكتشاف حزمة [C: \ P3X_FW_V01.01.0008.bin] ، بطاقة sn [0x29c00dcd].
[00012722] بدء ترقية الحزمة ...
[00012813] فحص الحزم ...
[00012904] فشلت ترقية الحزمة عند فحص الحزمة.
[00012530] ========== قطع الاتصال عن بعد. التمهيد (15) =============
[00012617] تم اكتشاف حزمة [C: \ P3X_FW_V01.01.0008.bin] ، بطاقة sn [0x29c00dcd].
[00012706] بدء ترقية الحزمة ...
[00012796] فحص الحزم ...
[00012889] فشلت ترقية الحزمة عند فحص الحزمة.
[00012745] ========== قطع الاتصال عن بعد. التمهيد (15) =============
[00012831] تم اكتشاف الحزمة [C: \ P3X_FW_V01.11.0030.bin] ، بطاقة sn [0x29c00dcd].
[00012921] بدء ترقية الحزمة ...
[00013010] فحص الحزم ...
[00013103] Packet vlink 01.11.0030 <-> 01.11.0020.
[00013191] تسجيل vlink 01.11.0030 <-> 01.11.0020 (التدفق = 0).
[00013281] تم.
[00013369] تدقيق الإصدار [1] ...
[00013495] [06 03] [00] v2.4.20.50 -> v2.4.20.50
[00013640] [05 03] [00] v34.2.0.9 -> v34.2.0.9
[00013736] [04 00] [00] v1.48.0.0 -> v1.48.0.0
[00013895] [11 00] [00] v1.8.0.0 -> v1.8.0.0
[00014060] [11 01] [00] v1.8.0.0 -> v2.0.0.33 ، البرنامج الثابت v1.8.0.0 لا يدعم.
[00014146] [11 01] [00] v1.8.0.0 -> v2.0.0.33
[00014288] [00 12] [00] v1.13.0.0 -> v1.13.0.0
[00014448] [01 12] [00] v1.13.0.0 -> v1.13.0.0
[00014584] [02 12] [00] v1.13.0.0 -> v1.13.0.0
[00014708] [12 03] [00] v1.13.0.0 -> v1.13.0.0
[00014902] [15 00] [00] v1.1.2.0 -> v1.1.2.0
[00015045] [00 17] [00] v1.1.1.7 -> v1.1.1.7
[00015227] [17 01] [00] v1.0.2.7 -> v1.0.2.7
[00015324] [00 19] [00] v1.0.8.96 -> v1.0.8.96
[00015416] [01 00] [00] v1.32.5432 -> v1.32.5432
[00015502] [01 01] [00] v1.32.5432 -> v1.32.5432
[00015624] [08 00] [00] v0.13.0.7 -> v0.13.0.7
[00015728] [09 00] [00] v4.1.0.0 -> v4.1.0.0
[00015815] تم إلغاء ترقية الحزمة عند فحص الإصدار.
[00012544] ========== قطع الاتصال عن بعد. التمهيد (15) =============
[00012728] تم اكتشاف الحزمة [C: \ P3X_FW_V01.11.0030.bin] ، بطاقة sn [0x29c00dcd].
[00012814] بدء ترقية الحزمة ...
[00012906] فحص الحزم ...
[00012995] رابط vlink 01.11.0030 <-> 01.11.0020.
[00013084] تسجيل vlink 01.11.0030 <-> 01.11.0020 (التدفق = 0).
[00013173] تم.
[00013263] تدقيق الإصدار [1] ...
[00025852] [06 03] [00] لم يتم اكتشاف الجهاز.
[00038447] [05 03] [00] لم يتم اكتشاف الجهاز.
[00038559] [04 00] [00] v1.48.0.0 -> v1.48.0.0
[00051143] [11 00] [00] لم يتم اكتشاف الجهاز.
[00063743] [11 01] [00] لم يتم اكتشاف الجهاز.
[00076328] [12 00] [00] لم يتم اكتشاف الجهاز.
[00088914] [12 01] [00] لم يتم اكتشاف الجهاز.
[00101507] [12 02] [00] لم يتم اكتشاف الجهاز.
[00114095] [03 12] [00] لم يتم اكتشاف الجهاز.
[00114299] [15 00] [00] v1.1.2.0 -> v1.1.2.0
[00126886] [17 00] [00] لم يتم اكتشاف الجهاز.
[00139485] [17 01] [00] لم يتم اكتشاف الجهاز.
[00152073] [00 19] [00] لم يتم اكتشاف الجهاز.
[00152169] [01 00] [00] v1.32.5432 -> v1.32.5432
[00152255] [01 01] [00] v1.32.5432 -> v1.32.5432
[00152366] [08 00] [00] v0.13.0.7 -> v0.13.0.7
[00152472] [09 00] [00] v0.0.0.0 -> v4.1.0.0 بحاجة إلى ترقية.
[00152566] تم.
[00154652] في انتظار تأكيد المستخدم ...
[00164748] انتهت المهلة ، ابدأ الترقية تلقائيًا.
[00164926] ترقية البرامج الثابتة [1] ...
[00165043] [09 00] بدء ترقية البرنامج الثابت ...
[00217281] [09 00] تم الانتهاء من ترقية البرنامج الثابت بنجاح.
[00217377] تم.
[00217464] تدقيق الإصدار [2] ...
[00217601] [06 03] [00] v2.4.20.50 -> v2.4.20.50
[00217740] [05 03] [00] v34.2.0.9 -> v34.2.0.9
[00217843] [04 00] [00] v1.48.0.0 -> v1.48.0.0
[00218020] [00 11] [00] v1.8.0.0 -> v1.8.0.0
[00218180] [11 01] [00] v1.8.0.0 -> v2.0.0.33 ، البرنامج الثابت v1.8.0.0 غير مدعوم.
[00218266] [01 11] [00] v1.8.0.0 -> v2.0.0.33
[00218420] [00 12] [00] v1.13.0.0 -> v1.13.0.0
[00218550] [01 12] [00] v1.13.0.0 -> v1.13.0.0
[00218683] [02 12] [00] v1.13.0.0 -> v1.13.0.0
[00218833] [03 12] [00] v1.13.0.0 -> v1.13.0.0
[00219012] [15 00] [00] v1.1.2.0 -> v1.1.2.0
[00219149] [00 17] [00] v1.1.1.7 -> v1.1.1.7
[00219324] [01 17] [00] v1.0.2.7 -> v1.0.2.7
[00219610] [00 19] [00] v1.0.8.96 -> v1.0.8.96
[00219705] [01 00] [00] v1.32.5432 -> v1.32.5432
[00219798] [01 01] [00] v1.32.5432 -> v1.32.5432
[00219907] [08 00] [00] v0.13.0.7 -> v0.13.0.7
[00220030] [09 00] [05] v4.1.0.0 -> v4.1.0.0
[00220118] تمت ترقية الحزمة بنجاح.
[00012721] ========== 2018.06.08 23:32:22. التمهيد (15) =============
[00012812] تم اكتشاف الحزمة [C: \ P3X_FW_V01.11.0030.bin] ، بطاقة sn [0x29c00dcd].
[00012907] بدء ترقية الحزمة ...
[00013202] تسجيل vlink 01.11.0030 <-> 01.11.0020 (التدفق = 0).
[00013295] تم.
[00013398] تدقيق الإصدار [1] ...
[00013527] [06 03] [00] v2.4.20.50 -> v2.4.20.50
[00013659] [05 03] [00] v34.2.0.9 -> v34.2.0.9
[00013770] [04 00] [00] v1.48.0.0 -> v1.48.0.0
[00013955] [00 11] [00] v1.8.0.0 -> v1.8.0.0
[00014128] [11 01] [00] v1.8.0.0 -> v2.0.0.33 ، البرنامج الثابت v1.8.0.0 لا يدعم.
[00014226] [11 01] [00] v1.8.0.0 -> v2.0.0.33
[00014369] [00 12] [00] v1.13.0.0 -> v1.13.0.0
[00014495] [12 01] [00] v1.13.0.0 -> v1.13.0.0
[00017146] [02 12] [00] v1.13.0.0 -> v1.13.0.0
[00017303] [03 12] [00] v1.13.0.0 -> v1.13.0.0
[00017509] [15 00] [00] v1.1.2.0 -> v1.1.2.0
[00017665] [00 17] [00] v1.1.1.7 -> v1.1.1.7
[00017858] [17 01] [00] v1.0.2.7 -> v1.0.2.7
[00017972] [00 19] [00] v1.0.8.96 -> v1.0.8.96
[00018065] [01 00] [00] v1.32.5432 -> v1.32.5432
[00018164] [01 01] [00] v1.32.5432 -> v1.32.5432
[00018267] [08 00] [00] v0.13.0.7 -> v0.13.0.7
[00018404] [09 00] [00] v4.1.0.0 -> v4.1.0.0
[00018500] تم إلغاء ترقية الحزمة عند فحص الإصدار.
[00012602] ========== 2018.06.08 23:33:19. التمهيد (15) =============
[00012698] تم الكشف عن الحزمة [C: \ P3X_FW_V01.11.0030.bin] ، بطاقة sn [0x29c00dcd].
[00012792] بدء ترقية الحزمة ...
[00012889] فحص الحزم ...
[00012985] رابط vlink 01.11.0030 <-> 01.11.0020.
[00013082] تسجيل vlink 01.11.0030 <-> 01.11.0020 (التدفق = 0).
[00013183] تم.
[00013276] تدقيق الإصدار [1] ...
[00013435] [06 03] [00] v2.4.20.50 -> v2.4.20.50
[00013732] [05 03] [00] v34.2.0.9 -> v34.2.0.9
[00013834] [04 00] [00] v1.48.0.0 -> v1.48.0.0
[00013992] [11 00] [00] v2.0.0.33 -> v1.8.0.0 ، البرنامج الثابت v2.0.0.33 لا يدعم.
[00014090] [00 11] [00] v2.0.0.33 -> v1.8.0.0
[00014272] [11 01] [00] v2.0.0.33 -> v2.0.0.33
[00014418] [00 12] [00] v1.13.0.0 -> v1.13.0.0
[00014554] [12 01] [00] v1.13.0.0 -> v1.13.0.0
[00014711] [02 12] [00] v1.13.0.0 -> v1.13.0.0
[00014876] [12 03] [00] v1.13.0.0 -> v1.13.0.0
[00015076] [15 00] [00] v1.1.2.0 -> v1.1.2.0
[00015239] [00 17] [00] v1.1.1.7 -> v1.1.1.7
[00015454] [17 01] [00] v1.0.2.7 -> v1.0.2.7
[00015580] [00 19] [00] v1.0.8.96 -> v1.0.8.96
[00015671] [01 00] [00] v1.32.5432 -> v1.32.5432
[00015769] [01 01] [00] v1.32.5432 -> v1.32.5432
[00015889] [08 00] [00] v0.13.0.7 -> v0.13.0.7
[00016022] [09 00] [00] v4.1.0.0 -> v4.1.0.0
[00016116] تم إلغاء ترقية الحزمة عند فحص الإصدار.
TK-62119
