Mark The Droner
Premium Pilot
- Joined
- Aug 26, 2015
- Messages
- 5,351
- Reaction score
- 1,773
RTH is easy to send regardless of setup and/or connection. All you have to do is turn the controller off.
Wait.
Turn on the controller.
Wait. Ignore the app.
When you see the AC in the sky coming towards you, you can then cancel RTH and land the AC.
DJI Susan's post contradicts your information. According to you, when the freq is 2.4 between the AC and controller, the freq is 5.8 between the controller and mobile device. But that doesn't make sense because if that was true, people in the USA who are using 2.4 between the AC and controller would likely not have connection with the 5.8 between controller and mobile device. I believe the connection between controller and mobile device is 2.4 in the USA, regardless of what it is between AC and controller. I may be wrong, but that is what seems to be implied and that is what she seems to be saying in her post.... DJI Susan just confirmed what I mentioned before. No confusion there any more.
It's easy to send an RTH command to AC at any time regardless of what is happening. Simply turn off the controller. This initiates RTH every time.For safe flight first you need is reliable control signal, than telemetry and at last video feed. Not to mention that video signal occupies most of the carrier signal (for commands and telemetry you basically need few bytes of info). Philosophy is very simple, you must be able to send command "RTH" even without video and telemetry feed, regardless DJI Go setup. At least I would do it that way...
Wait.
