Cases or backpacks for P3?
GPC is currently hard at work on a P3 backpack. Here is their Hard Case that was previously pictured in this thread which is practically the same one they had at NAB. Layout is slightly different. We are not sure if this will be the final layout or not but you can definitely expect something very similar to this layout.
Phantom 3 Hard Protective Case: www.advexure.com/store/dji-phantom-3-case
my p3 fits right into my p2 gopro case, feels a lot more snug the way I wish my p2 fit in it. probably still pick up the p3 case anyways though lol
Reactions: Advexure
Do you have a pic of the P3 in there?
Specifically how does the controller fit?
My p2v+ in the backpsck and p3 in gopro case. With the lid closed it holds the controller perfect. If i trim the foam a bit the p3 controller will fit perfect where the p2 goes.
awesome!! i'm about to order mine, debating on the hardcase or backpack. I know eventually I will need both. Do you guys have a coupon code for dronesetc?
I have been using the Multistar P2 backpack from hobbyking with my P3 and it's worked perfectly. It's far cheaper than most other options and is actually pretty comfortable.
IMG_2418 by laselvasurf, on Flickr
Reactions: Farmer
jumperswaves
