- Joined
- Nov 29, 2015
- Messages
- 111
- Reaction score
- 17
- Age
- 84
Why update? I have not done a update in 17 months to my P3A and it flies fine
I have the same issue with my Samsung Tab S2. I have to go through the setup each time I want to fly the drone, do you? Just bought a CrystalSky, expensive way to solve a problem, but it works.I have had problems with my Samsung Tab S2 connecting to my P4A. To solve this I enabled developer options in the tablet settings. Then go to USB configuration and select RNDIS Ethernet. Do this after the drone and RC are powered up and plug in the USB cable.
What do you mean by "kill codes?" I haven't done a software upgrade yet, and now I need some info on this before I even consider it.Talking with 2 reputable DJI dealers, I was told unofficially the DJI has started sending out kill codes. I was warned do not do any further updates to my P3P.
(cross-posted on DJI forum)
I am trying very hard to remain civil, but after two months of not being able to use my P3P I'm kinda upset.
I am a FAA 107 licensed remote pilot with 350+ flights on my P3P with a GL300B RC . I've always kept my firmware updated to the latest version. The last update, P3X_FW_V01.11.0020.bin, completed successfully on the P3P, but DID NOT complete successfully on the controller via the GO app. I've been able to re-link the controller with the P3P, in that I can control the gimbal, start recording & start the motors. But GO refuses to see the P3P and connect.
So my first thought was to downgrade the RC firmware. When I hold down the GO hamburger menu for that, it says my current firmware version is "N/A", and no previous version is shown to roll-back-to. And being that it's a GL300B, the firmware can only be updated via the GO app (which it clearly won't) -- I can't use the USB port like on the GL300A (Hey DJI -- did somebody there actually said "I know -- let's take away the ONE FEATURE that would allow users recover from a failed firmware upgrade on their RC so they have no where to turn". Brilliant, but not a good way to get users to upgrade to a P4).
Anyway, here's what else I've tried many-multiple times:
-- Tried at least a half-dozen high-quality USB cables.
-- Tried with the latest GO on the following devices:
- Samsung 6 edge
- Samsung Galaxy-Tab-E-8.0
- Samsung SMT320 (used for the 350+ flights)
- iPad2
-- Tried all of the C1+C2+Shutter+scrollwheel combinations on the RC that are supposed to re-set to factory defaults and force an emergency firmware update.
The only thing I have left is to try progressively older versions if GO to see if any will recognized the corrupted or missing RC firmware and do an update, but that sounds like a long shot in the dark that I'll undertake if nothing else.
I also spent a couple hours on the DJI tech support chat -- no help at all -- my dog has a better understanding of the product!
I've also spoken to the support staff at two San Francisco repair facilities (one is DJI's authorized service center). Both told me that this is a "known problem", and the only solution is to send my controller into DJI, or just buy another used RC!!! That clearly implies that DJI's firmware update DAMAGED my RC, and I see dozens if not hundreds of other P3A and P3P users who are in the same situation -- after weeks of online sleuthing I have yet to see anyone find a solution.
So I challenge DJI, and any users here who think they know the solution, to post it here. I will follow your instructions to the letter and promptly let you know the results.But don't bother posting links to another forum posts unless they are newer than this one, because I've read/tried 'em all.
I've loved DJI products for the last 3 years, but what I won't do is pay to have DJI "fix" the problem they introduced. If that is truly the only solution, I will say adios DJI, and they will lose a strong advocate.
Thanks for reading my rant, and I look forward to all replies.
Again! Dump DJI Go and use Litchi and forget firmware updates! ...snip...
Good luck
Jim
WA5TEF
Personally, I would leave it as is. The buyer may prefer the earlier version. Let them decide.Hello friends, Long time no see. My p3p has been sitting most of the time so now I would like to sell it. I locked the dedicated Nvidia shield wifi access down when the bird was on 1.9.60 (and it's been working great ever since). Now my question is should I update it before selling it? If I try the update, do I have to stop off at different levels or can it go straight to the latest? Thanks in advance.
That would be it!Well, I went ahead with the update. The bird updated just fine but somehow I forgot how to update the controller. All the utube videos said just stick the same file in the USB slot. When that didn't work, I connected with the bird and stumbled through the update via the app. I sure didn't want the new buyer asking me how to update.
