• Advertisement
Advanced search
DJI Lens Correction for Videos
Discuss the DJI Phantom Vision Camera and FPV System
Moderators: Adam, gunslinger, DeweyAXD, Geert, BenDronePilot
  • Advertisement
The World's Best Personal Drone
Re: DJI Lens Correction for Videos
Postby gunslinger » Mon Dec 09, 2013 12:27 pm
BenDronePilot wrote:
Pull_Up wrote:A question for those more versed in the ins and outs of lenses than I...
When DJI release the 46mm lens filter adapter kit, is there anything available that could be fitted to that to do a correction? Or is putting it in front of the lens just not going to work? As you can tell, I have no idea about any of this!
Also, does anyone have any video they can share which they took with the 90 degree FOV, just to compare? Thanks...
I have three videos on my Ben7seven7 YouTube channel currently showing the Phantom 2 vision with the 1080p 30 FPS 90 degree angle view. It's not 100% perfect but there is little to no obvious lens distortion, especially as compared to people filming video on wide. Here is a link to one of them.
http://youtube.com/watch?v=tpaYVU5JTio
Thanks for the info. I'm going to try this on my next flight. When my last video was "corrected" there was considerable "banana bounce." Enough to make you dizzy.
Thanks again...
-slinger
Phantom 2 Vision with RotorPixel Gimbal, FlyTrex Core 1, new style TX and RE700.
Dromida Ominus with LaTrax Alias prop shafts and props
A squadron of Hubsan X4s with various mods
Estes Proto X
User avatar
gunslinger
Advertisement
Postby rmklaw » Mon Dec 09, 2013 12:33 pm
Thank you all for the valuable suggestions. It took almost an hour to do the rendering. It was just a test because it was my first flight. The rendering looks great without curves.
Richard
rmklaw
Postby Firestat » Mon Dec 09, 2013 3:39 pm
Very nice video in Queens. But I am confused: How do you shoot at "90 degrees"? Not sure what that means.
Chuck
Firestat
Postby Pull_Up » Mon Dec 09, 2013 3:44 pm
It's the field of view of the camera. You can select different FOVs (for video only, not stills) in 1080p mode - it's from within the app.
User avatar
Pull_Up
Postby BenDronePilot » Mon Dec 09, 2013 5:20 pm
Firestat wrote:Very nice video in Queens. But I am confused: How do you shoot at "90 degrees"? Not sure what that means.
Chuck
Thanks, glad you like the video, feel free to check the others out. I could give links if needed. And the field of view is selected to the right of your resolution setting.
BenDronePilot
Postby Firestat » Tue Dec 10, 2013 8:31 am
Pullup, thanks for that info. I will have to take a look at that.
Chuck.
Firestat
Postby hulihee » Wed Dec 11, 2013 9:39 am
I was able to get the photoshop lens correction for my video. It definitely takes some time to render, but I'm cutting down my footage first, and only lens correcting the clips that I'm going to use which is a huge time saver.
What I'm not sure is, what export settings should I use within photoshop for exporting basic 720 and 1080 video shot at 30fps? I'm unfamiliar with DXF format?
I'm editing primarily with Final Cut Pro (can't use .mp4)
hulihee
Postby jimre » Wed Dec 11, 2013 1:10 pm
hulihee wrote:I was able to get the photoshop lens correction for my video. It definitely takes some time to render, but I'm cutting down my footage first, and only lens correcting the clips that I'm going to use which is a huge time saver.
I think you meant to type DPX, not DXF (that would be an AutoCAD file). DPX = Digital Picture eXchange, a standardized format used to submit footage to professional Hollywood production & special-effect companies. Probably not something most of us would ever use.
If you're going to do further video editing & processing on this footage, you'll get the best quality renders if you choose QuickTime->Uncompressed. This will result in huge files but you won't lose video quality at each intermediate step. Ideally, only the final version should be compressed into H.264/MP4.
jimre
Postby BigSky » Wed Jan 15, 2014 12:28 am
BenDronePilot wrote:I've got a better solution for you. Shoot your videos in 90 degree angle like I do so you get virtually no lens distortion or fisheye that way.
How will shooting at 90 degrees change that? And you would have to be horizontal to your subject to capture it that way. What if you want shots looking downward? I guess I don't understand something here.
User avatar
BigSky
Postby BigSky » Wed Jan 15, 2014 12:30 am
jimre wrote:
rmklaw wrote:Thanks. I am doing it now. Slow process.
Yep, Photoshop renders video very slowly, and has limited rendering choices. Dedicated video apps like Adobe Premiere, Adobe After Effects, Sony Vegas or others will render video much faster and make better use of your CPUs and GPUs processing power. Photoshop's automatic correction based on lens profiles is nice - but for video it may not be worth putting up with Photoshop's slow rendering.
It may be better to use the built-in lens-distortion correction filters found in dedicated video apps - like the one in After Effects. Not automatic based on a lens profile, but it's easy to manually move a slider until it looks good. And they render a lot faster than Photoshop.
Is After Effects a free download App?
User avatar
BigSky
PreviousNext
  • Advertisement
Return to DJI Phantom Vision
Who is online
Users browsing this forum: 1st_time_flyer, Bing [Bot], mcurrier and 15 guests
  • Advertisement
