• Advertisement
Advanced search
how to update vision firmware?
Discuss the DJI Phantom Vision Camera and FPV System
Moderators: Adam, DeweyAXD, gunslinger, BenDronePilot
  • Advertisement
The World's Best Personal Drone
Postby uncle fester » Sat Nov 23, 2013 7:17 pm
is there any step by step instructions on how to install this? i gave it a go but quickly got pissed off with it.it said i need 2 plug in controller so i did then it was saying theres no controller grrrrrrrr i hate computers!
uncle fester
Advertisement
Re: how to update vision firmware?
Postby JustJames » Sat Nov 23, 2013 8:09 pm
This has been a hot topic. Read through here http://phantompilots.com/viewtopic.php?f=7&t=3964 If you have specific questions I will try to help if I can. Im no guru..far from it but I have successfully stumbled my way throughout it and now have a fair understanding of how to do it.
I hope this helps. Good luck brother.
James
User avatar
JustJames
Postby MikeON » Sat Nov 23, 2013 8:18 pm
Did you install the DJI driver for Windows or Window 8 before trying the firmware updates? That was necessary for it to work for me.
MikeON
Postby uncle fester » Sat Nov 23, 2013 8:42 pm
MikeON wrote:Did you install the DJI driver for Windows or Window 8 before trying the firmware updates? That was necessary for it to work for me.
cheers ima give it another go 2nyt yup i downloaded the driver fine but now im stuck
uncle fester
Postby MikeON » Sat Nov 23, 2013 8:53 pm
when you get the "no controller" message, do you have it plugged into the quadcopter itself, or the remote controller?
MikeON
Postby uncle fester » Sat Nov 23, 2013 9:02 pm
MikeON wrote:when you get the "no controller" message, do you have it plugged into the quadcopter itself, or the remote controller?
i had it plugged into the controller so then i also turned the controller on still nothing
uncle fester
Postby iDrone » Sat Nov 23, 2013 9:25 pm
When you turn the controller on, do you get a green light? If so, does it beep (once/twice)? If not, reconnect its microUSB to your computer, launch RC Assistant and click the upgrade button again - don't worry that it doesn't see it yet or show your current firmware version. It should resume & complete the upgrade then ask you to cycle the power switch.
iDrone
User avatar
iDrone
Postby urgno » Sun Nov 24, 2013 8:33 am
I had the same problem not being able to connect the controller
at the end the issue was that the controller was recognized as msh brain
(fbl controller I use on helis) removing that software did recognize the dji controller correctly and I was able to update firmware
the lesson is: look in windows device manager and see if the dji controller appears with the right name ;-)
User avatar
urgno
  • Advertisement
Return to DJI Phantom Vision
Who is online
Users browsing this forum: Baidu [Spider] and 7 guests
  • Advertisement
