• Advertisement
The World's Best Personal Drone
Advanced search
Compass calibration...
Discuss the DJI Phantom Vision Camera and FPV System
Moderators: Adam, DeweyAXD, gunslinger, BenDronePilot
  • Advertisement
Postby gunslinger » Mon Nov 11, 2013 11:11 am
I never had any problems until the first time I calibrated the compass. Now I'm having erratic problems in flight.
Today I went to a new field and calibrated the compass before I got it off the ground. The calibration went well and I was sure to be in the middle of an open field, away from the TX and the iPhone. No powerlines... Nothing... It flew perfectly for quite some time, then I noticed it wasn't responding correctly to input from the TX. It wasn't hovering properly. I carefully brought it down and when it was closer to the ground it was reacting as though I was giving it forward stick. If I pulled back on it I could slow the speed quite a bit. When I got about two feet off the ground, I cut the engines and it tumbled just a bit.
I calibrated the compass again and it seemed to go as smoothly as last time, though I only flew it close to the ground for a limited time. Between this and the battery issues, things are getting a little scary here...
Anyone else seeing this?
Phantom 2 Vision with RotorPixel Gimbal, FlyTrex Core 1, new style TX and RE700.
Dromida Ominus with LaTrax Alias prop shafts and props
A squadron of Hubsan X4s with various mods
Estes Proto X
User avatar
gunslinger
Advertisement
Re: Compass calibration...
Postby Pull_Up » Mon Nov 11, 2013 11:18 am
Only the once, after I calibrated in a stupid place with most of the things you avoided right near it. I've seen two schools of compass dance. The "official" way (as espoused by DJI's Colin in the latest "how to fly your Vision" video) is to just hold it up off the ground a bit, keep it level-ish, rotate it in your hands in one axis, then the other. I've also see people grip their phantom by the legs whilst holding at arm's length and rotate themselves around, flip the phantom so holding by the bottom of the skids and then do the whole pirouette at arm's length again for the other axis.
The latter would seem to guarantee a smoother, more level rotation, but you're not doing it around the actual axis of the craft. I don't know how sensitive the compass is to being out of vertical/horizontal and whether that even matters much...
User avatar
Pull_Up
Postby gunslinger » Mon Nov 11, 2013 11:45 am
Pull_Up wrote:Only the once, after I calibrated in a stupid place with most of the things you avoided right near it. I've seen two schools of compass dance. The "official" way (as espoused by DJI's Colin in the latest "how to fly your Vision" video) is to just hold it up off the ground a bit, keep it level-ish, rotate it in your hands in one axis, then the other. I've also see people grip their phantom by the legs whilst holding at arm's length and rotate themselves around, flip the phantom so holding by the bottom of the skids and then do the whole pirouette at arm's length again for the other axis.
I've seen both methods as well and I'm using the one Colin recently displayed... I just re-calibrated again and plugged the PV into my PC and ran the Vision Assistant. Numbers look normal. X=265 Y=-45 Z=340 with the MOD at 1534. The PV was pointed more or less North at the time...
-slinger
Estes Proto X
User avatar
gunslinger
Postby A1962 » Fri Nov 15, 2013 9:56 pm
New pilot here preparing for first flight. I am all booted up and connected but for one problem -- i can not get the phantom to enter compass calibration mode. s1 switch (the right side toggle switch) up and down 10 times -- nothing happens, and i still have blinking yellow or blinking green indicator lights.
What am i doing wrong? Thanks
A1962
Postby Richhealth » Fri Nov 15, 2013 11:09 pm
A1962 wrote:New pilot here preparing for first flight. I am all booted up and connected but for one problem -- i can not get the phantom to enter compass calibration mode. s1 switch (the right side toggle switch) up and down 10 times -- nothing happens, and i still have blinking yellow or blinking green indicator lights.
A few things to double check come to mind.
Are you sure the phantom and the transmitter are connected/paired?
When switching the s1 ( the toggle on the right side of the transmitter ) are you going from the very top, to the very bottom, up and down ten time, ending in the up position? It may be going from the top to the middle position! Just a thought in case you didn't realize it's a 3 position switch.
Lastly, are you waiting until,the initial warm up phase is over and it goes into the gps mode with slow flashing green lights?
Hope something in this helps, good luck, and safe flying.
Rich
Richhealth
Postby Pull_Up » Sat Nov 16, 2013 4:12 am
Rich gave good advice, it took me a few tries to get it. The most important thing is to let everything settle for a while before trying to calibrate. I find if you wait until your app is all connected and ready then it's a good time to try and calibrate. The other thing I've found helps is not to do the switching either too fast or too slow. About 2 complete up and downs per second. I also count out to make sure I'm actually doing ten... try counting "and" as you flip all the way down then saying "1" as you hit top position again... (e.g. "and 1, and 2, and 3....") That way you'll end up in the upper position after 10 cycles and can check those LEDs.
Good luck!
User avatar
Pull_Up
Postby yanimage » Tue Nov 19, 2013 3:33 am
I have also problems to get phantom to compass calibration mode. I tried this several times when phantom was out of the box and nothing happens. Now I upgraded to new firmware, but still same problem.
I do not know what to do next ... well I think I'll go fly :)
yanimage
Postby urgno » Tue Nov 19, 2013 6:40 am
not good to fly without compass calibration :roll:
User avatar
urgno
Postby gunslinger » Wed Nov 20, 2013 7:58 am
urgno wrote:not good to fly without compass calibration :roll:
Been there... done that... had minor cardiac event... replaced props... :shock: :o
-slinger
Estes Proto X
User avatar
gunslinger
Postby urgno » Wed Nov 20, 2013 9:59 am
-slinger
had a major cardiac event ... replaced all phantom vision :cry:
User avatar
urgno
  • Advertisement
Return to DJI Phantom Vision
Who is online
Users browsing this forum: No registered users and 3 guests
  • Advertisement
