• Advertisement
Advanced search
DJI is making a alert sound when i plug in battery
Are you having a problem with your DJI Phantom?
Moderators: OI Photography, DeweyAXD
Postby gadgetboy32 » Mon Jun 24, 2013 7:17 pm
My dji is not starting up the standard sound when you plug in the battery, instead it's making a high pitch sound and not starting up. What do I do?
I was updating the software and accidently unplugged the USB from the computer and not it wont start up
is there a reset button or something? :o :o
here's the vid of what happening
http://www.youtube.com/watch?v=zbaz8WTC ... e=youtu.be
jimmy
gadgetboy32
Advertisement
DJI Spring Promotion 2015 - Save up to 15%
Re: DJI is making a alert sound when i plug in battery
Postby Driffill » Mon Jun 24, 2013 10:40 pm
I'm only guessing here, but I'd say you have corrupted the naza firmware when it disconnected . . . .
Try running the update again and see if it connects up to the software etc, make sure you have all controls working and responding as they should, and if all at goes well, try flying again.
If there is an issue, you may need to contact DJI, I'm guessing they have delt with corrupted firmwares before, but weather it can be fixed or not is a different story.
I come from a hobby of car ECU re-flashing, basically changing the firmware of the cars ECU. When ever there is data flow between the car and laptop, touching the cables or plugs is a big NO NO! If anything goes wrong with the flash process, the car is practically useless, and can only be revived thru a factory dealership (generally for around $1000~2000)
Driffill
Postby jumanoc » Tue Jun 25, 2013 7:42 am
gadgetboy32 wrote:My dji is not starting up the standard sound when you plug in the battery, instead it's making a high pitch sound and not starting up. What do I do?
jimmy
Hey, that sounds exactly when there is 1 or more motor wires disconnected from Naza FC. Open hull and double check theh all wires ar fitted tight into Naza sockets.
User avatar
jumanoc
  • Advertisement
Return to Help
Who is online
Users browsing this forum: No registered users and 7 guests
  • Advertisement
