• Advertisement
Advanced search
Shapeways Undertray with Fatshark TX compartment - IS HERE!
DJI Phantom Quadcopter General Discussion
Moderators: Adam, ElGuano, LuvMyTJ, DeweyAXD, OI Photography, gunslinger
  • Advertisement
The World's Best Personal Drone
Postby DeweyAXD » Tue Jun 11, 2013 10:13 am
Well thanks mostly to Simensays for inspiring me to get back into 3D modelling. I have just taken my first stab at using Shapeways with this:
It is a custom undertray with a compartment specifically modelled for the (lumpy) stock Fatshark 5.8 TX that comes with the Predator V2. The TX slots into the housing and has plenty of cooling vents. I messed around with clips for the cap but I don't know what the material properties are like for fixings so this version will need an m3 nut & bolt (or just tape).
It will be mounted by 4 x male to female 25mm brass hex spacers that replace the innermost landing gear screws (they are like £2 on ebay).
All going well it will be with me on 20th July. If it stands up to the test I'll probably tweak the bugs out and start a little Shapeways shop so people can buy it. If it does work it looks likely to be about $35 - $40 (€35 - €40 Europe) + P&P and my calculations have it around 10 grams in weight.
Anyway I thought I'd share to see peoples reactions. Probably overkill but screw it even if just mine works I'll be dead chuffed cause I forgot how fun 3D modelling with a real purpose was! :mrgreen:
** See/Buy my custom Phantom parts on Shapeways: http://www.shapeways.com/shops/d3wey **
** See my other RC projects: http://www.rcgroups.com/forums/member.php?u=499128 **
** My YouTube Channel: https://www.youtube.com/user/d3weyTube **
User avatar
DeweyAXD
Advertisement
Re: Shapeways Undertray with Fatshark TX compartment - beta
Postby GearLoose » Tue Jun 11, 2013 11:13 am
I can't really comment on the Fatshark undertray because I don't (yet) have FPV. But, it is good to see more Phantom users getting into accessory design and production.
I'd like to have a very simple multi-use "platform" that would allow me to attach my Drift HD action cam, or my Garmin GPS (just for the fun of it, for one or two flights), or a big flashing strobe light, or... whatever crazy idea hits me from time to time.
GearLoose
Postby DeweyAXD » Tue Jun 11, 2013 12:09 pm
GearLoose wrote:I can't really comment on the Fatshark undertray because I don't (yet) have FPV. But, it is good to see more Phantom users getting into accessory design and production.
Thanks for the feedback there. I have a version without the TX compartment and i was working on modulising it too but I need to make sure I didn't balls up the dimensions before I try that.
Am I right in think that the Drift HD has a tripod thread in the base? If so I could easily come up with a mount for that to convert it to make it compatible with the goPro fixing.
User avatar
DeweyAXD
Postby GearLoose » Tue Jun 11, 2013 1:12 pm
Yes, the Drift has a tripod thread -- it also has a lens that can be twisted, so it is easy to orient the image "right side up". Now if I can just buff the scratches out of the lens protector (from a crash), it will be ready for your mount ;)
GearLoose
Postby DeweyAXD » Tue Jun 11, 2013 3:58 pm
Well this is what I've come up with if you were ever interested?
As you can see it is basically a GoPro mount to Camera hotshoe bracket. You would then get a Hotshoe to Tripod adapter like this for a about £2.50 from ebay. The alloy ones are good and weight 20grams max.
You undo the knurled nut, slide the mount into the hotshoe/gropro, srew it down tight. Then do the same at the other end on the camera (maybe with an extra 1/2 inch nylock nut for security).
PM me if you are interested.
User avatar
DeweyAXD
Postby simensays » Tue Jun 11, 2013 5:19 pm
Cool to see that you're gettin' back into CAD work.
Looking forward to seeing more of your ideas & designs!
User avatar
simensays
Postby Maxxborg » Tue Jun 11, 2013 11:34 pm
Very Cool!
User avatar
Maxxborg
Postby DeweyAXD » Wed Jun 12, 2013 11:08 am
Thanks guys. Looking forward to seeing how it comes out but I'll knock a few ideas up in the meantime for fun probably!
User avatar
DeweyAXD
Postby DeweyAXD » Tue Jun 18, 2013 4:23 pm
Well today I took delivery of my creation! Having just had a dissapoinment over the weight of a 2mm carbon fibre rigid sheet I was really looking forward to this!
First impressions....
Well it is very thin and light at a mere 22 grams. That is 2 grams less than my 'sandwich box' option and a whole 17 grams less than the 2mm carbon fibre (which I am sure i could get to around 25 grams in 1mm cut down format).
While it feels quite thin (probably a little too thin in places) you can tell that it is robust. Good start.
Tray Fitment...
Well for attaching the tray to the 25mm Male-Female hex spacers my measurements were spot on. Clips into place and screws go through the holes as required.
TX Fitment....
My Fatshark stock TX slid straight into the slot and is a perfect fit. The plugs slip through the slot I created and hold firm.
The door needed the slightly rough edges sanding down ever so slightly for a nice fit. There is no play with it in situe and as you can see the heat distribution slots line up where i wanted them. Plenty of air will get to it in flight that is for sure.
Cables...
Not rocket science but this worked how i wanted. Under and over can be applied to most of the cables with the smaller fixings. As shown here I have used the velcro slots to route some of them. Operators choice really!
All assembled in just FPV form (Hero3, Fatshark with Filter, one batt, Garmin GTU10).....
Extra Batt as an option?.... Yes (pics to follow). 1250g with 2 batts and all the listed equiptment but that will come down 50-60 grams by replacing the GoPro skeleton housing with the DJI mount (or GoPro 'Frame'). Likewise even less weight if you opt for 2 batts and just stock Fatshark camera (no Hero) and not everyone has a 75 gram GTU10 onboard either.
Conclusions...
Well overall I'm really quite happy with it! Flight testing will commence when a replacement bearing for one of my motors arrives in the morning (noticed it yesterday).
Beta Issues...
There are a couple of minor ones. Easy and obvious fixes without needing a dozen more models being built. The main issue is the lack of bracing above the TX holder. It means it has a slight flex from the weight of the TX/Aerial. This might add to nothing but it could become pronounced under load of the probs. It won't break but it might cause an unwanted vibration and no one wants that! Time will tell.
Being that the dimensions and fitment are all good I can make these changes and see how the pricing comes out. I'd expect if anyone other than me did want one it'd be about €35 ($31)... plus postage of course. Might just leave it as a bit of fun for myself unless people show interest! Feeback as always is welcome!
User avatar
DeweyAXD
Re: Shapeways Undertray with Fatshark TX compartment - IS HE
Postby Maxxborg » Wed Jun 19, 2013 12:04 pm
I think this is awesome. I just wished it was made in a way that I could mount it with my gimbal. I would probably preorder one if so. I hate velcro and tape that I do on my Fatshark setup. Something that looks and feels more legit.
User avatar
Maxxborg
Next
  • Advertisement
Return to General Discussion
Who is online
Users browsing this forum: ccase39, NOMADIXaerial and 6 guests
  • Advertisement
